| New Reply |
What is the reason for absolute zero temperature? |
Share Thread | Thread Tools |
| Feb17-13, 08:18 PM | #1 |
What is the empiric reason behind the assumption that there is lowest thermodynamic temperature (absolute zero)? And that all other temperatures of bodies in thermodynamic equilibrium are always higher ?
I am looking for a reason not using the entropy concept, as the entropy was derived historically with the assumption that there is lowest temperature which ideal gas can have. So the argument using entropy would be circular. Or do you think that entropy is more fundamental than temperature and positive thermodynamic temperature is a just a consequence the properties of entropy ? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Feb17-13, 08:49 PM | #2 |
| Feb17-13, 09:18 PM | #3 |
I know such view is quite common, but if I want to avoid statistical physics, it is hard to introduce entropy first and then temperature as a derived concept. Historically, the temperature is assumed first and the entropy is derived, by the consideration of Carnot cycles - this is the way entropy was discovered. So I wonder whether there is some non-statistical, non-entropic argument for the positive temperature, which would make the historical path more sensible.
| Feb17-13, 09:27 PM | #4 |
I guess I don't even understand your question. Temperature is a measure of the motion of matter. If there is no motion, the temperature is zero. What's confusing about that?
| Feb17-13, 09:42 PM | #5 |
| Feb17-13, 10:17 PM | #6 |
Even in classical thermodynamics temperature is a derived quantity from the Carnot engine.
Also 0 is not the lowest possible temperature: http://en.wikipedia.org/wiki/Negative_temperature |
| Feb17-13, 10:31 PM | #7 |
$$ pV = nRT $$ and total energy $$ U = ncT. $$ with some constant ##c##. According to the second equation, temperature is a measure of total energy ##U##. But energy is an abstract concept, which can be negative in principle. (It will be other contributions to energy are negative and great enough). Then according to the second equation, the temperature will be negative too. |
| Feb17-13, 10:33 PM | #8 |
| Feb17-13, 10:44 PM | #9 |
Curl,
I know of " negative temperatures" as sometimes applied to spins and laser, but those are different thing from what I have in mind. As wikipedia says, But this is not without objection - such systems are not stable so it can be argued they do not have temperature at all. I am thinking of a concept of temperature applied only to systems in equilibrium, with which, when a body has temperature -5 K, one says the body is truly colder than the system with 0 K, so heat will flow from 0 K to -5 K. |
| Feb18-13, 01:52 AM | #10 |
Recognitions:
Entropy may be more fundamental than temperature, but it cannot be measured directly, unlike temperature.
| Feb19-13, 12:25 AM | #11 |
I have never seen temperature defined in terms of anything other than entropy, and in some books, using carnot engines.
I guess another way to describe it is "temperature is the thing that is the same for two objects if they are in thermal equilibrium". Then you can say that when an object cannot give any more thermal energy, it is at 0K. But obviously this is a very weak statement and in no way a definition. |
| New Reply |
| Thread Tools | |
Similar Threads for: What is the reason for absolute zero temperature?
| Thread | Forum | Replies | ||
| intuitive reason absolute values are used for transformations in statistics? | Calculus & Beyond Homework | 5 | ||
| Absolute Zero, about -273.15ºC, is the coldest known temperature | General Physics | 12 | ||
| what is absolute body temperature? | General Physics | 4 | ||
| negative absolute temperature | Advanced Physics Homework | 1 | ||
| What is absolute temperature? | General Physics | 10 | ||
