Poisson vs Binomial distribution.
by Jcampuzano2
Tags: binomial, distribution, poisson
Jcampuzano2
Jcampuzano2 is offline
#1
Feb19-13, 01:22 PM
P: 3
Hello PF
This might be a fairly simple question to most of you, but I was given this problem (don't worry, I already solved it just wondering about something)
Suppose the probability of suffering a side effect of a certain flu vaccine is 0.005. If 1000 persons are inoculate, find the approximate probability that
(a) at most 1 person suffers, (b) 4,5, or 6 persons suffer.
I already solved it, but this problem is in the chapter on the Poisson distribution. Unfortunately my teacher didn't cover this distribution in detail, but when I first looked at the problem it look like a typical Binomial distribution problem? I later figured out I was supposed to approximate with the Poisson distribution.
Why would we use an approximation for the Binomial when we could just apply it, and under what circumstances am I allowed to make this approximation in the first place?
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
micromass
micromass is offline
#2
Feb19-13, 03:11 PM
Mentor
micromass's Avatar
P: 16,703
The problem with the binomial distribution is that it is very hard to calculate.
So the second question would be
[tex]\sum_{k=4}^6 \binom{1000}{k} (0.005)^k0.995^{1000-k}[/tex]
This is the correct answer. But computing those binomial coefficients is not very fun.
However, we can show that if we are working with binomial(n,pn) distributions and if [itex]np_n\rightarrow \lambda[/itex] for some [itex]\lambda[/itex], then
[tex]\binom{n}{k} p^k (1-p)^{n-k} \rightarrow e^{-\lambda} \frac{\lambda^k}{k!}[/tex]
So, if n is very large and p is very small, then the Binomial(n,p) distribution is very close to the Poisson(np) distribution.
So, in our case, p=0.005 is small and n=1000 is large. The product is medium: 5. So we can approximate the answer by
[tex]\sum_{k=1}^6 e^{-5} \frac{5^k}{k!}[/tex]
And we are also rid of that pesky binomial coefficient.
This approximation is also theoretically interesting. The sum of two (independent) Poisson distributions is always a Poisson distribution, for example. But the sum of two (independent) binomial distributions is not binomial.
ImaLooser
ImaLooser is offline
#3
Feb20-13, 01:47 AM
P: 571
Quote Quote by Jcampuzano2 View Post
Hello PF
Partly it is holdover from the old days when computation was expensive. The teaching of statistics hasn't changed much in the past 50 years, as far as I could tell. The binomial is still tricky to compute because the factorials in the intermediate results can be very large and you have to be careful not to get computer overflow.
You can use the Poisson approximation when n is large (greater than 50 is probably enough) and when the chance of 0 successes or n successes is negligible. It depends on how much accuracy you need, so there can be no hard and fast rule.
Register to reply
Related Discussions
Why does Binomial dist. converge in distribution to Poisson dist. ? Set Theory, Logic, Probability, Statistics 5
Practical use of binomial and Poisson Distribution in the field of engineering Set Theory, Logic, Probability, Statistics 1
Poisson distribution and binomial distribution questions Linear & Abstract Algebra 1
Confusion on Poisson and Binomial Distribution Set Theory, Logic, Probability, Statistics 10
Binomial, Poisson and Normal Probability distribution help!! Precalculus Mathematics Homework 6
