| New Reply |
Charge for a Grain of Dust on the Moon? |
Share Thread |
| Feb19-13, 09:28 PM | #1 |
1. The problem statement, all variables and given/known data
How much charge in Coulombs is required to levitate a motionless grain of dust 10 cm above the surface of the moon? Assume the dust grain is a point mass with mg = 1*10^-9g. The gravitational acceleration at the surface of the moon is 1.6m/s^2. Assume charge on the surface of the moon acts as a point source beneath the grain equal in charge to the grain itself. 2. Relevant equations E = F/q0, a = (q0/m)*E, e = 1.60*10^-19 C, E = 8.988*10^9 N*m^2/C^2 3. The attempt at a solution Any help would be greatly appreciated! I figured that the first step is to find the variables known, so the acceleration is 1.6m/s^2 = (q0/(1*10^-9g))*(8.988*10^9), so would I just need to solve for q0? Thanks so much! |
| Feb19-13, 10:32 PM | #2 |
Recognitions:
Draw a free-body diagram for the grain of dust - what are the forces acting on it?
| Feb19-13, 11:18 PM | #3 |
Would there only be one force against it towards the surface of the moon? Or is there also one from the moon pointing towards the grain?
| Feb19-13, 11:30 PM | #4 |
What about if I used the equation Fnet = m * a, which would be 1.6*10^-9?
| Feb20-13, 12:02 AM | #5 |
Recognitions:
However - if the dust thingy is levitating, doesn't that mean the net force on it is zero? |
| Feb20-13, 12:07 AM | #6 |
Sure, so if the net force is zero, then would I need an equation using the acceleration? Thanks for your help.
| Feb20-13, 12:33 AM | #7 |
Recognitions:
Have you drawn the free body diagram?
Have you identified the different forces on the dust? |
| New Reply |
Similar discussions for: Charge for a Grain of Dust on the Moon?
| Thread | Forum | Replies | ||
| Grain size and grain boundary diffusion | Materials & Chemical Engineering | 2 | ||
| Charge on the dust particle? | Introductory Physics Homework | 8 | ||
| Absence of dust on moon and material sciences | Astrophysics | 5 | ||
| Why are Grain Dust explosive? | General Physics | 10 | ||
| average grain diameter at 310MPa from 2 known yield/grain values | Engineering, Comp Sci, & Technology Homework | 2 | ||
