Why is the cross product perpendicular?
The cross product of two vectors is defined as a vector that is perpendicular to the plane formed by those vectors. This perpendicularity is demonstrated mathematically by showing that the dot product of the cross product with each of the original vectors equals zero. The matrix definition of the cross product reinforces this concept, as it results in a determinant that becomes zero when evaluated with either of the original vectors, confirming their orthogonality. The cross product is unique in producing a vector perpendicular to two given vectors, making it a valuable tool in vector mathematics. Its utility is evident in various applications where a perpendicular vector is required.
JizzaDaMan
Why is the cross product of two vectors perpendicular to the plane the two vectors lie on?
I am aware that you can prove this by showing that:
(\vec{a}\times\vec{b})\cdot\vec{a} = (\vec{a}\times\vec{b})\cdot\vec{b} = 0
Surely it was not defined as this and worked backwards though. I see little advantage in making this definition, and simply guessing it seems a bit random, so what brings it about?
Mathematics news on Phys.org
What is your definition of the cross product?
By the matrix definition of the cross product we have
\vec{a}\times \vec{b} \cdot \vec{c} <br /> = \begin{vmatrix} \vec{i} &amp; \vec{j} &amp; \vec{k} \\ a_i &amp; a_j &amp; a_k \\ b_i &amp; b_j &amp; b_k \end{vmatrix} \cdot \vec{c}<br /> = (\vec{i} \begin{vmatrix} a_j &amp; a_k \\ b_j &amp; b_k \end{vmatrix} -\vec{j} \begin{vmatrix} a_i &amp; a_k \\ b_i &amp; b_k \end{vmatrix} + \vec{k} \begin{vmatrix} a_i &amp; a_j \\ b_i &amp; b_j \end{vmatrix} ) \cdot \vec{c} \\ <br /> = (c_i \begin{vmatrix} a_j &amp; a_k \\ b_j &amp; b_k \end{vmatrix} -c_j \begin{vmatrix} a_i &amp; a_k \\ b_i &amp; b_k \end{vmatrix} + c_k \begin{vmatrix} a_i &amp; a_j \\ b_i &amp; b_j \end{vmatrix} )<br /> = \begin{vmatrix} c_i &amp; c_j &amp; c_k \\ a_i &amp; a_j &amp; a_k \\ b_i &amp; b_j &amp; b_k \end{vmatrix}.
When \vec{c} = \vec{a} or \vec{c} = \vec{b} the determinant has two equal rows and becomes zero. This means the dot product is zero and the vectors are perpendicular.
The cross product is the (up to multiplication by a constant) only product possible that takes two vectors to a third. It is also extremely useful to produce a vector perpendicular to two given vectors. All the time you have two vectors and need one perpendicular to them. Bam! Cross product done.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
