New Reply
Factoring Method
Share Thread Thread Tools
Feb20-13, 06:33 PM   #1
Factoring Method
Hello,
I'm currently learning all about factorization techniques for a college project. I know that most of the advanced techniques are based around a congruence of squares. As part of our research we've been asked to think up an original factoring method. It doesn't matter how slow or fast it is as long as its original, and we get bonus points for this if we can prove it's original. I have thought of a method, although I don't think it is original, but I'm not sure, so I've come on here to check.
I'll give the method with some examples which I've been working through in excel. Tbh I've been working through many examples, and I've hit the number limit with excel which is above 10 digits or something.
Anyway, here goes:
Example (1): Factorize the number 77.
Method: 77 = 8^2 + 13
13-8 = 5, 5^2 + 4.13 = 77
Now we have that 77 = 8^2 + 1.13 ...(1)
and 77 = 5^2 + 4.13 ...(2)
Now multiply (1) by 2^2, giving 308 = 16^2 + 4.13 ...(3)
Then subtract (2) from (3) giving 231 = 16^2 - 5^2
Then factorise 77 as gcd(77, 16-5)*gcd(77,16+5) i.e. 77 = 11 * 7
Example (2): Factorize the number 8791.
Unlike with 77, which worked on the first attempt, this only works at the third attempt. Each attempt multiply the number in question by 1,2,3,4,5...
So attempts 1 and 2 didn't result in a square being generated, but attempt 3 does:
3*8791 = 26373 = 162^2 + 129
Now do Abs(129 - 162) = 33
33^2 + 196.129 = 26373
So we have that: 162^2 + 1.129 = 26373 ...(1)
33^2 + 196.129 = 26373 ...(2)
Now multiply 1 by 14^2 (=196) to give: 2268^2 + 196.129 = 196.26373 ...(3)
And: 33^2 + 196.129 = 26373
Subtracting (2) from (3) gives: 2268^2 -33^2 = 195.26373
Thus 8791 = gcd(2268-33, 8791)*gcd(2268+33,8791) = 149 * 59
Example (3): Factorize 8414786257.
A square was found in excel at the 1496th attempt.
1496*8414786257 = 3548030^2 + 3359572 = 188458^2 + 3736489.3359572
i.e. 1496*8414786257 = 3548030^2 + 3359572 = 188458^2 + (1933^2).3359572
Thus gcd(1933.3548030-188458, 8414786257) = 104297
and gcd(1933.3548030+188458, 8414786257) = 80681 Q.E.D.
I hope someone will be able to give me some feedback on this. As I say, I don't think this method can possibly be fully original, but I may get partial credit for any original element? Thanks for your help in this. :D
I'm running into a bit of a problem with excel, because of floating point integers and the limits with representation. I'd like to test out this method on larger integers, maybe using C. I'm a bit rusty on it at the moment, so if anyone could implement it fairly quickly and let me know how the results shape up I'd be grateful. I've reached the limit with what can be done with excel. This is the largest number I've been able to factorize thus far: 30,436,307,070,163. It's only 14 digits long. I want to test this method with semiprime numbers up to 20 or 30 decimal digits at least. 30,436,307,070,163 was factorized as follows.
At the 10,560th attempt a square was found:
10,560*30,436,307,070,163 = 566,928,040^2 + 122,679,680 = 444,248,360^2 + (31,799^2)*122,679,680
Thus gcd(31,799*566,928,040-444,248,360; 30,436,307,070,163) = 8,589,337.
The other factor is gcd(31,799*566,928,040+444,248,360; 30,436,307,070,163) = 3,543,499
From previous posts on this site, I've seen somewhere that a method must be tested for numbers greater than 2^64 to see if it is truly effective, and this falls well short of that, which is about 20 decimal digits, although this last factorization is much better than trial division, since sqrt(30,436,307,070,163) = 5,516,911 and there are about 382,000 primes below this number, hence 10,560 attempts is not bad at this stage. However I think this will be insufficient as the numbers grow larger, but I have no idea as I lack the ability to test this out on C at the moment. If anyone could quickly check this out by seeing how it performs with two 15 digit primes, spaced not too close together, I would be very grateful to them.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Feb21-13, 07:15 AM   #2
you write:
5^2 + 4.13 =77
that's wrong. 5^2 + 4.13 =25+4.13 =29.13
same thing with your equations 1 and 2. How can 77 be equal to 8^2 + 1.13 ?
and what exactly do you mean by ... in equation 1 and 2?
Feb21-13, 08:13 AM   #3
Quote by epsi00 View Post
you write:
5^2 + 4.13 =77
Its pretty obvious that the period stands for the multiplication sign. You can take that approach when you have a given that you are not working with decimals. However, I think that the op could have used the more conventional * to make it more clear.
Feb21-13, 08:18 AM   #4
Factoring Method
I havn't seen this method of factoring before. However, proving it original may be a problem. You may try the wolfram site to work math problems with large numbers.
Feb21-13, 08:26 AM   #5
Recognitions:
Gold Membership Gold Member
It seems to me that it is a modified form of Fermat factoring. A^2 - B^2 Is the next to the last step.
Feb21-13, 08:48 AM   #6
Recognitions:
Retired Staff Staff Emeritus
Quote by coolul007 View Post
It's a precursor to Dixon's method.
Quote by Jopus View Post
Python is probably a better choice; it has arbitrary precision integers built-in, and is generally easier to program in.
Feb21-13, 09:07 AM   #7
Recognitions:
C as well as JAVA have the BigInterger type, fairly easy to use.
Feb21-13, 10:07 PM   #8
Here's a list of factorization methods
http://en.wikipedia.org/wiki/Integer_factorization
you may want to compare your method to the ones above.
New Reply
Tags
composite, factor, factorization, integer. semiprime
Thread Tools
Similar Threads for: Factoring Method
Thread Forum Replies
How does the AC method of factoring quadratics work? General Math 8
Finding the Relationship between the Limit Method and Direct Integral Method for Area Calculus & Beyond Homework 7
Factoring question - generalized factoring in integers Linear & Abstract Algebra 0
ODE - Comining Undetermined Coefficients Method with Variation of Parameters Method Calculus & Beyond Homework 2
washer method and disc method for finding volumes of graphs Calculus 5
