| New Reply |
Exact Purpose of Hemispherical Heads? |
Share Thread | Thread Tools |
| Feb21-13, 02:23 PM | #1 |
These days you hear often about cars having "Hemis". Correct me if I'm wrong, but the hemispherical head allows for a slight increase in volumetric efficiency of the cylinders, but is there any other advantages to it?
Thanks for you help! |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Feb21-13, 10:03 PM | #2 |
It makes for a snappy marketing pitch.
Apart that, few people could tell what advantages it might bring. I'm not sure there is actually any volumetric efficiency improvement, although there has been lots of work to optimize the mixing of the fuel with the air by fine tuning the valve positions and the shape of the combustion chamber. I believe that engines have been run with glass ports to allow laser beams to monitor the fuel/air mixing and combustion. |
| Feb21-13, 11:08 PM | #3 |
There are both advantages and disavantages to using hemispherical heads. Just check the Wiki page, for examples of both. A Google search brings much more discussion of them.
Cheers, Bobbywhy |
| Feb22-13, 08:53 AM | #4 |
If you ever fly through Hartford Connecticut, take a couple hours to see the aviation museum across the field from the terminal.
One of the exhibits is an inverted V-8 aircraft engine with hemispherical heads, made by Chrysler in 1930's. It flew 400 mph in 1939. The hemispherical chamber allows big valves for a free breathing engine. In 1950's Chrysler advertised "aircraft technology" in their passenger car engines and these are the legendary "hemi's" that you still hear about today. It didnt take hot-rodders long to figure out they could be made quite powerful. This one likely began its life in a 1957 New Yorker.
| Feb22-13, 10:06 AM | #5 |
Hemi heads have been the engine builds choice for years. Chrysler and Ford Hemis rule in drag racing. A circle is the optimum shape for vector resolution
(reacts equally to forces from all directions). Taking this one step further, when you introduce fuel/air mixture in a Hemi sphere combustion chamber and light it, you have uniform burning of the mix and force is applied in the most practical manner. Compare this to the typical wedge combustion chamber design which does not have best flame travel and force is staggered as the mix expands and applies force to the piston surface. Additional advantages are huge valves may be used, and depending upon the design Dual overhead cam design being the best, you can really pack in the mixture. Disadvantage is the EPA did not like the emmissions and was not the best fuel economy engine out there,,it would pass everything thing on the road but a gas station... My opinion |
| Feb25-13, 06:50 PM | #6 |
I'm an aircraft mechanic, and when I went through my training, they didn't really touch hemispherical heads.
So, in essence, it's just to allow greater flow into the cylinder by allowing larger valve heads to have more room? |
| Feb25-13, 06:53 PM | #7 |
| Feb26-13, 04:00 AM | #8 |
i believe you have two spark plugs for safety sake. If one fouls out the engine still runs.
| Feb26-13, 06:31 AM | #9 |
Safety is one part, but if you foul out a single plug in one cylinder, on an engine that has single plugs, you still are running on the other cylinders. The main purpose of the dual plugs is the even flame propagation. It helps eliminate hot spots and detonation in combination with the tetraethyl lead that is added to the 100 octane fuel.
| Feb26-13, 06:14 PM | #10 |
| Feb26-13, 06:21 PM | #11 |
Got it. On a side note, what are your opinions on Wenkel (rotary) engines?
| Feb26-13, 06:52 PM | #12 |
Mentor
| Feb26-13, 07:14 PM | #13 |
I don't know. But didn't the Mazda Rx7 have one?
| Feb26-13, 09:35 PM | #14 |
That results in an unfavorable fraction of heat from combustion, which should go into expanding the working fluid , instead just lost by conduction into the walls. I owned a 1973 Mazda RX2, bought it brand new Sept '02.. I figured such a tiny car would get tremendous gas mileage - some of you may recall that was when cost of gas skyrocketed to almost 50 cents per gallon. Piston economy cars of the day approached 30 mpg. Well, i never saw over 18mpg on the little rotary beast. So i quipped: "I'd save money to put the Mazda in the trunk of my Chrysler and keep on driving it." My opinion of the Wankel - an interesting idea but not a good one. To its credit - the RX2 was quite powerful and gave me 100k miles of reliable service. It was a small, expensive gas guzzler. I'll take Detroit Iron any day. 1951 Chrysler Hemi car engine: Photo credit to these kind folks: http://evolutsia.com/content/view/614/44/ Observe how the angled valves allow them to be oversize compared to cylinder bore. Now, imagine a domed piston that raises the compression ratio up to around 13::1 ... This paragraph is NOT a commercial endorsement, just sharing a good experience: If you're ever in Ocala Florida plan on a day in Don Garlits' '' Museum of Drag Racing. " It's right on I95. I liked the machinery. My greater half Fair Anne, who is an artist, was so entranced by the paint jobs I had to drag her away at closing time ! photo courtesy Don Garlits ![]() http://garlits.com/museum.htm old jim |
| Feb26-13, 09:51 PM | #15 |
Yes. The hemi head design allows a much better port to valve design and a permits a central spark plug placement in the cylinder. This permits a very straight port to valve design This design has dominated NHRA top fuel drag racing for the last 50 years.
| Feb27-13, 03:43 AM | #16 |
Jim Hardy..excellent!!
| Feb27-13, 11:45 AM | #17 |
i made an error above post though -- Garlits museum is on highway I-75 not I-95. Too late to edit it today.. Since the air-fuel mix needn't make an abrupt turn, the engine "breathes" freely. You can see this on right side of photo. It helps get a full charge into the cylinder at high power high speed operation. old jim |
| New Reply |
| Thread Tools | |
Similar Threads for: Exact Purpose of Hemispherical Heads?
| Thread | Forum | Replies | ||
| what is the purpose of the general purpose registers, segment | Electrical Engineering | 4 | ||
| Rod in a hemispherical bowl | Introductory Physics Homework | 0 | ||
| 50 coin tosses, probability of 25 heads vs 3 heads | Precalculus Mathematics Homework | 7 | ||
| A stirring Rod in a hemispherical bowl | Advanced Physics Homework | 1 | ||
| What do you do if your exact equation isn't exact? and they give u an Integrating F | Calculus & Beyond Homework | 2 | ||
