Variable valency explanation and cause
Transition elements, such as iron (Fe), exhibit variable oxidation states due to their electronic configurations and the energy stability of different states. While they may not strictly follow the octet rule, the underlying reason for their variable valency is linked to energy minimization in electron configurations. Non-transition elements, like nitrogen, also display variable valency, indicating that the octet rule is a simplistic model. A deeper understanding requires knowledge of computational chemistry to analyze the stability of various electron configurations.
  • Understanding of transition metals and their properties
  • Familiarity with oxidation states and electron configurations
  • Knowledge of the octet rule and its limitations
  • Basic principles of computational chemistry
  • Explore the electronic configurations of transition metals using tools like ChemDraw
  • Study the principles of energy minimization in electron configurations
  • Learn about computational chemistry techniques, such as density functional theory (DFT)
  • Investigate the variable valency of non-transition elements, focusing on nitrogen
Chemistry students, educators, and researchers interested in transition metal chemistry and the principles governing variable valency in elements.
adi1998
many transition elements have variable oxidation state like Fe.what is the exact cause for this?they may not obey the octet rule,but what is the reason behind this?Also,elements like nitrogen are not transition elements and still show variable valency.what will be the electronic configuration of such elements?is it always according to aufbau principle?then which electrons will take part in the reaction,like in Fe---1s1,2s2,2p6,3s2,3p6,4s2,3d7
Chemistry news on Phys.org
Octet rule is obeyed mostly by 2nd row elements, and even then not always, so don't treat it as a starting point. The real force behind is the energy - the lower the energy, the more stable the configuration. Sometimes energy is particularly low for some configurations and these are the only ones we observe, but more often there are several configurations, each with their own energy minimum (not much different from others), and all are observed.
octet rule is a very crude approximation for main group elements. for a quantitative reason why electron shells are what they are, you need computational chemistry.
  • · Replies 16 ·
16K
