Visible Spectrum and the Compton Effect
The discussion revolves around the Compton effect and its observability when using light from the visible spectrum. Participants explore the differences in energy and momentum between visible photons and higher-energy photons like X-rays, as well as the implications for detecting the Compton effect in various contexts, including interactions with electrons and materials.
  • Some participants note that the energy of a photon affects its momentum, with visible photons having significantly less energy and momentum compared to X-ray photons.
  • One participant explains that a visible photon may cause an electron to move to a higher energy shell but lacks the energy to fully eject it from the material.
  • Another participant raises a question about whether the wavelength of a visible photon is too large relative to the electron's size, making the Compton effect undetectable.
  • Participants discuss the measurable wavelength shift in the Compton effect, noting that the shift for visible photons is too small to be detected with current spectrometers.
  • One participant suggests that the Compton effect may only be noticeable for visible photons when the scattering angle exceeds 54 degrees, based on calculations involving wavelength shifts.
  • Another participant introduces the concept of spectral linewidth due to the Heisenberg uncertainty principle, arguing that this linewidth makes it difficult to distinguish the Compton shift from the original photon source.
  • Some participants inquire about the Compton effect's observability when X-rays rebound from metals, discussing the role of the photoelectric effect in this context.
  • One participant emphasizes that the Compton effect primarily occurs with high-energy X-ray photons and low atomic number materials, describing the process of Compton scattering.
Participants express various viewpoints on the observability of the Compton effect with visible light, with some agreeing on the challenges posed by energy levels and spectral linewidths, while others raise questions and propose different conditions under which the effect might be observed. Overall, the discussion remains unresolved with multiple competing views.
Participants mention limitations in measuring small wavelength shifts and the dependence on specific conditions such as scattering angles and material properties, which remain unresolved in the discussion.
wolfgang
Hi,I need some help here.
Why the Compton effect can not be noticed when we are using light from the visible spectrum?
The energy of the photon also determines the momentum of the photon. That is, a high energy photon is a high momentum photon.
In the Compton effect, an electron recoils after a collision with a photon, and this recoil acts just like a classical conservation of momentum collision.
A visible photon has much less energy than an x-ray. We're talking a thousandth to ten-thousandth less energy, and therefore that much less momentum.
A collision with a visible photn whould knock an electron into a higher shell, temporarily, but much more energy is required to knock it completely out of the material
what is the Compton effect?
The question remain.
Thanks for trying to answer me Mr Chi but my problem remain,I will make myshelf clear.
If the wavelength of the X-ray photon before the collision with the electron is ë then after the collision the wavelength of the X-ray becomes bigger because the X-ray photon looses a part of its momentum because of the interaction with the electron.
Let’s call this new bigger wavelength ë’. When we are using X-rays the Compton effect is noticeable because the difference ë’-ë is measurable, but when we are using visible photons the ë’ is equal to ë and we can not notice the Compton effect.
And my question is the following:
The wavelength does not change because the ë of the visible photon is 100000000 times bigger than the diameter of the electron and so the photon actually can not see the electron? or because the changing of the momentum during the collision is so small that the difference between ë’ and ë can not be measured in our labs?
What is really happening I am very curious,aren't you?
The wavelength shift in the Compton effect depends only on the mass of the particle with which the effect takes place. The maximal shift occurs when the photon bounces back at 180 degrees. For The Compton effect with a photon and an electron' the change in wavelength is about 0.02 Angstroms. So when your photon is in the visible light, you just cannot see this difference.
more questions
You are obviously talking about the equation of Compton:
ë´- ë= L(1- cosö).
Where L is equal to L=h/mc=0.02426 Angstroms (for the electron) so the shift ë´- ë of the photon is between 0 < ë´- ë < 0.04852 Angstroms
(because 0< 1-cosö < 2).
We know that the modern spectrometers has resolving power of 0.01 Angstroms so we can measure shifts of the wavelength which are bigger than 0.01 Angstroms. This means that:
ë´- ë > 0,01 Á and ëc(1- cosö) > 0.01 A if we do the calculations we will get that we can measure shifts of the wavelength when the change of the angle is bigger than 54 degrees.
If my thoughts are correct then the Compton effect is not noticeable when the change of the direction of the visible photon during the collision with the electron is smaller than 54 degrees? Is that correct??
Can we say that the Compton effect with a visible photon and an electron it is noticeable only when ö>54 degrees?
The frequency of a monochromatic source is never completely monochromatic (Due to Heisenberg's uncertainty principle), it has a finite spectral width (linewidth). The natural linewidth (Linewidth due to HUP), is usually around 8 MHz, which corresponds to a wavelength difference of around 0.03 angstroms in the visible, which is roughly the same wavelength change induced by the compton shift.
Hence it is quite impossible to spectrally differentiate between the Compton shifted radiation and the original source.
Claude.
Oh, I like that! I was doing the math trying to come up with an answer but... I don't think I've ever come across this explanation before.
I totally believe your explanation, Claude, it makes total sense; but could you name a text, or website, or book that corroborates this?
TIA
Any textbook with a section on lasers will probably deal with spectral linewidths.
'Laser Electronics' by Verdeyen, 'Lasers and Electro-Optics' by Davis and 'Laser Fundamentals' by Silfvast are a few examples.
Hyperphysics has a decent page on natural linewidths: http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/parlif.html
Claude.
Thanks. My books are a little old; so's my memory it seems: can the Compton effect be observed when x-rays rebound from metals? I seem to remember that it is, but I can't find any reference to it.
Hi,
Indeed Claude Bile your explanation was very clever.
I would not think of it.
Thank you anyway :wink:
"The only thing I know is that
I don't know anything"
Socrates
Hi,
I think that this not so “simple” as the collision between an X-ray photon and an electron. This is because here appears the photoelectric effect.
The free electrons of the metal can absorb only photons that have energy bigger than the extraction work of the metal.
So if the X-ray has energy equal or bigger than the extraction work then there is no X-ray rebounding because it is absorb by the electron. But if the X-ray’s energy is less than the extraction work we can notice the Compton effect.
Socrates
The Compton effect occurs primarily in the absorption of high X-ray energy and low atomic numbers. The effect takes place when high X-ray energy photons collide with an electron. Both particles may be deflected at an angle to the direction of the path of the incident X-ray. The incident photon having delivered some of its energy to the electron emerges with a longer wavelength. These deflections, accompanied by a charge of wavelength are known as Compton scattering.
  • · Replies 21 ·
  • · Replies 27 ·
12K
