Consistency of the speed of light
The discussion centers on the consistency of the speed of light as stated in Einstein's second postulate of special relativity. Participants explore the implications of this postulate, its experimental verification, and the philosophical underpinnings of its acceptance within the framework of relativity.
  • Some participants note that the speed of light is treated as a postulate in special relativity, which cannot be proven but is assumed for theoretical consistency.
  • Others argue that while the speed of light has been consistently measured to be the same across various frames, this does not rule out the possibility of it varying under unmeasured conditions.
  • A few participants reference the idea that special relativity is empirically equivalent to ether theories that incorporate time dilation and length contraction, suggesting that no experiment has definitively distinguished between these views.
  • Some contributions emphasize that postulates can be verified through experiments, and that the speed of light can be measured from moving sources, citing specific studies as evidence.
  • There is a contention regarding the interpretation of postulates, with some asserting that they are assumptions that cannot be derived from first principles, while others maintain that they can be experimentally verified.
  • One participant suggests that the second postulate is a consequence of Newton's first law and the homogeneity of time, indicating a potential foundational relationship between classical mechanics and relativity.
Participants express multiple competing views regarding the nature of the speed of light as a postulate, its experimental verification, and its implications for theories of relativity and ether. The discussion remains unresolved with no consensus on these points.
Some claims rely on specific experimental results and interpretations that may not be universally accepted. The discussion highlights the complexity of verifying fundamental postulates and the philosophical implications of their acceptance in scientific theory.
  • #61
With all these posts no one has stated the reason that SR was needed in the first place. Also how could a forum not include posts from people who don't agree with einstein. This is truly intellectual censorship. No wonder we have had to endure 100 years of relativity, this is what all of the colleges also do, so there are no new ideas.
First I'll answer my first question; Why was relativity needed at all? For that we need to go back to the Michaelson Morley experiment. All of great minds at that time, believed that the Earth traveled through space, in a so called aether. This aether carried light waves at the speed of light in space. So if the Earth was moving in relation to this aether, then the observed speed of light on the Earth would be c + v, where c is the constant speed of light in space, and v is the speed of the observer, in this case the Earth as it moves through so called aether. obser-c = c + v. Of course we know that they got a null result. No one could believe it. The greatest minds could not accept this. Let's see what this leads to, if you get a null result, what exactly is null? It is the velocity of the observer. This leads to this equation; v = constant of 0. Which means that no matter the velocity of the observer, relative to light his speed is 0. Since the observer is always a constant 0 velocity, then you need time and space to become variables. Which means you need relativity. Time and space had always been considered constant, and rightly so. I have much more to say but I'm not sure this is the right forum since it appears to be censored.
mike
  • #62
You'll find lots of posts on that topic if you look, but that wasn't the question. The short answer is "The negative results of the Michelson-Morley experiments".
Yep, we do have some forum guidelines here, which you've apparently read, though you've decided to disregard them. Please feel free to post your astounding intellectual ideas about why relativity is wrong to an unmoderated forum like, for example, usenet sci.physics.relativity, where "anything goes" and frequently does.
Oh, I see you already knew. Then why the heck did you try and hijack thre thread to ask the answer to a question that you already knew, and disregard the forum guidelines to boot?
  • #63
Aether said:
The conclusions of each of the papers can't be stretched any farther than to say that SR is empirically equivalent to Lorentz ether theory (LET). What they fail to do is to select LET over SR, but you are claiming that they somehow select SR over LET and that is not true either.
I've been looking at your doc which I turned into a readable version here:
(33 MB) http://chip-architect.com/physics/Mansouri&Sexl_2.doc I'll leave it here for 12 hours.
Aether,
Mansouri and Sexl make a statement that our world can be equally well
described by a transformation other then the Lorentz Transformation.
This is just as true as the statement that our world can be equally well
described by, say, for instance it's Fourier Transform. Although this is
mathematically correct, I is certainly not how we perceive our world.
We perceive non-simultaneity
Regards, Hans.
  • #64
proof for non simultaneity via computer simulation.
I use images here to proof the non simultaneity of SR rather than math.
I can't make it any simpler.
A remarkable amount of physics can be extracted from the simple rule
that the wave front is always at right angles with the physical velocity,
regardless of the reference frame.
The left half of the image below shows a fast particle chasing a slower
particle with equal mass. The fast particle has a shorter deBroglie
wavelength. The *phase* speed of the faster particle is slower (as given
by [itex]c^2/v[/itex] ) While the *phase* speed of the slower particle is higher.
At the right half we see the same scene from a reference frame moving
upwards. The extra motion has a larger influence on the slower moving
particle. Its relative motion changes downwards more than the faster
particle. As one can see, the combination of Special Relativity and
Quantum Mechanics makes sure that the wavefronts are exactly at right
angles with the physical speed, exactly as one would intuitively expect.
It is only Special Relativity which can rotate wavefronts, and it does so
for both light and matter waves. A Galilean transformation keeps the
wavefronts always directed in the same direction! The mechanism through
which Special Relativity manages this is again via the non-simultaneity
of time.
Regards, Hans
  • #65
Readers of this thread might find this article: Breaking Lorentz symmetry of interest. It is from Physics World, the magazine of the Institute of Physics, the professional body for physicists in Britain.
It mentions Mansouri-Sexl and puts their work into a wider context.
  • #66
pervect said:
I think pdf would work much better.)
Can you read Hans' version? If not, I'll post a pdf. I made a .pdf first, but it was very large so I wen't for a .doc; it wasn't any smaller though.
pervect said:
Opinions vary - I find that trying to apply non-SR theories is like trying to "climb a greased flagpole". Metaphorically, anyway, I've never actually tried to do that :-)
In my opinion, if LET wants to accomplish something, it has to at least suggest some experiments which might allow one to detect some sort of preferred frame. If it is just another formulation of SR, it's probably not going to catch on, unless it is simpler to teach (but I suspect that the current formalism is much simpler). It may have a small niche for those who can't adjust their personal philosphies to deal with SR.
Suppose that LET turns out only to be useful as a waypoint (for some) on the philosophical journey to SR. Even so, what is the justification for tolerating false (however well intentioned) claims that the constancy of the speed of light is an empirically determined fact? Why not just state up front that partiality to SR is simply a matter of coordinate choice, and not an empirical necessity?
  • #67
This is utterly silly. I can show you one, two, three, etc. examples of "new ideas" that came out of "colleges". When was the last time you read PRL? Will this be sufficient to show that your statement here is FALSE?
Say what? Relative to light, the observer's speed is ZERO? Do you know what you just said? Relative to me, my computer monitor has a speed of zero. We are both moving at the same speed then. You have just said the observer is moving at the same speed as light!
And this is your argument on why we needed SR? Oy vey! And to think colleges "censor" things like this! How dare they!
Zz.
  • #68
I have a .pdf of Hans' reformatted version of the Mansouri&Sexl papers (8MB) that I can make available on request.
Great article, thanks!
  • #69
I don't think so, Hans. We actually perceive only dimensionless ratios (http://arxiv.org/abs/hep-th/0208093), and all judgements of simultaneity ultimately depend on one's choice of clock synchronization convention.
Hans de Vries said:
A remarkable amount of physics can be extracted from the simple rule that the wave front is always at right angles with the physical velocity, regardless of the reference frame.
Suppose that you are right, doesn't this "simple rule" amount to the choice of Einstein's clock synchronization convention?
  • #70
Aether said:
I don't think so, Hans. We actually perceive only dimensionless ratios, and all judgements of simultaneity ultimately depend on one's choice of clock synchronization convention.
How's that? Right now, sitting at my desk, I've just observed someone tying his shoe, followed by someone else clicking a mouse. Why do I need a clock synchronization scheme to say which one comes first? And if some other observer goes zipping by at high speed and observes the events in reverse order, why would he need a clock synchronization scheme to say the opposite?
  • #71
In fact, The Lorentz transformations them self can be derived directly from
the single statement that "A wavefront is always at right angles with the
direction of the wave in all reference frames."
(This beauty already laid unrecognized in the M&M experiment)
The example I use here (with the Broglie wave functions) works at any speed
let is be at meters per second or centimeters per second.
Regards, Hans
  • #72
Hans de Vries said:
In fact, The Lorentz transformations them self can be derived directly from the single statement that "A wavefront is always at right angles with the direction of the wave in all reference frames."
Lorentz transformations amount to an arbitrary choice of Einstein's clock synchronization convention. Lorentz symmetry is equally well represented by transformations in which absolute simultaneity is maintained.
  • #73
Imagine,
Looking at one of the images in my post above sitting right in front of it.
Take a picture from sufficiently far away. The photo will group together all
the space/time points which have equal time in the particular reference frame.
There's no choice here.
Regards, Hans
PS: For two points, say one left and one right of the center, having the same
distance to the viewer. You can take a picture from any distance and you'll
always fetch the same two space/time points togeter. Even though you have
c going at all kinds of angles, with all kinds of different ratios of its x and y
components.
  • #74
Hans de Vries said:
Imagine,
Regards, Hans
components.
How do you know that these two points have the same distance to the viewer? What are you assuming about the speed of light? Aren't you assuming that its speed is constant and isotropic?
  • #75
You interpreted what you observed using a set of assumptions including that the speed of light is very fast, and that it is isotropic; right? That is where you adopted Einstein's clock synchronization convention. If you didn't use these assumptions, exactly which ones did you use? If I postulate that the speed of light is a function of the cosine of the angle that your velocity makes with some other velocity, say the CMB rest frame, then clocks are synchronized absolutely and judgments of simultaneity are generally different. You can transform freely between Einstein clock synchronization and absolute clock synchronization, and in doing so you change the directional speed of light.
A dimensionless ratio can not be freely transformed, and is the only truly invariant outcome for any measurement. For example, say that I measure my desk to be 2 meters wide; where is the dimensionless ratio? 2 meters per 1 meter of my meter stick: the ratio of my desk's width to my meter stick's length is 2/1. In any frame, this ratio sticks.
The speed of light is not a dimensionless ratio, and therefore it is not something that you can ever measure without reference to one artificial convention or another!
"When clocks are synchronized according to the Einstein procedure the equality of the velocity of light in two opposite directions is trivial and cannot be the subject of an experiment." - M-S I p.499
  • #76
OK, I've snagged the files (both sources), and will look them over when I get a chance. The .pdf definitely looks readable, I haven't tried the new .doc yet.
  • #77
Hans de Vries said:
It is only Special Relativity which can rotate wavefronts, and it does so for both light and matter waves. A Galilean transformation keeps the
wavefronts always directed in the same direction! The mechanism through which Special Relativity manages this is again via the non-simultaneity of time.
There are two things going on here, Hans. First there is Lorentz symmetry, and that is what is actually measurable in experiments. Galilean transformations fail those tests, and I am not implying otherwise.
The second thing that is going on is that Lorentz symmetry is conserved by at least two types of transforms: Lorentz transforms are one type, and they are characterized by postulating that the speed of light c is isotropic in all inertial frames (e.g., SR). However, there is a second type of transform (e.g., LET) where clocks and rods are isotropic in all inertial frames, but the speed of light is not. These two type of transforms are equally valid, and they have nothing whatsoever to do with any experimental result (so far). Interestingly, BOTH theories (SR & LET) would need to be modified upon the detection of a violation of Lorentz symmetry because they are empirically equivalent.
Violations of Lorentz symmetry are empirically measurable in principle, but the conventional choice as to which terms in the transform are constant and which terms are allowed to vary is not. So which one should we use? SR is convenient as long as you don't have a locally preferred frame to use as a "handle", but LET would be better if we ever find a handle.
It is wrong to claim that the constancy of the speed of light is proven by experiment. Does this go for GR as well? I suspect that it does, but I'm still studying GR myself and can't say for sure at this time.
  • #78
If you look at Einstein's original paper, Einstein *assumed* isotropy, which he did not define in great detail, to arrive at his theory of relativity.
Mansouri and Sexyl, from the papers I skimmed (thanks for posting them) are basically exploring the realm of physics of "what happens if one does not assume isotropy", though they don't discuss it in those exact terms. (I personally think their paper would be improved if they did at least mention the term "isotropy", it's got a lot of history).
A perfectly isotropic space-time can be made to appear non-isotropic by the proper (or improper) choice of clock synchronziation methods. So what Mansouri and Sexyl are basically doing is to *not* automatically choice a coordinate system that conforms to the (apparent) isotropy of space-time, by instead considering arbitrary clock synchronizations.
By not assuming isotropy as a given, (as Einstein did), Mansouri and Sexyl's work helps provide a framework for testing it. (Of course I should add that there is currently no evidence that there is any physical aniosotropy in space-time).
Their (M&S) general approach may also be useful in rotating coordinate systems, where the usual assumption of isotropy has issues. While one can always chose not to use rotating coordiantes, they are convenient enough that sometimes it's worth giving up the conveniences of isotropy for the convenience of using rotating coordinates.
  • #79
Zapper,
I believe what i said was correct. To throw out a universe with constant time and space, there had to be a reason. Every one accepted a constant time and space as fact. So it was the the MM experiment which led to SR, which led to variable space and variable time. If you have a constant velocity for the observer, then something else must be a variable, Einstein chose space and time. So the whole reason for coming up with SR is the MM experiment. Without the MM experiment, SR was not needed, and thus would never have been accepted in the scientific community.
And yes, relative to the constant speed of light, the observer's speed was 0.
Remember, everyone expected something other than 0, because they were looking for the so called aether. But the experiment was done in air, so relative to the air, the velocity of the interferometer was 0. Not a good experiment.
mike
  • #80
mike
What difference does it make what its velocity relative to the air is? Neither relativity nor the aether theory would predict your velocity relative to the air would make any difference in terms of the velocity you measure for light.
And "relative to the constant speed of light, the observer's speed was 0" doesn't make sense. You can only talk about your velocity relative to a thing like a car or a light wave, talking about your speed relative to a speed is meaningless. What is my speed relative to the speed of 70 mph? Maybe the idea you're trying to express is that the experimenters originally believed that only an observer whose velocity relative to the aether was 0 would see light moving exactly at c in all directions, whereas relativity predicts that every observer will see that. But this means that every observer has a speed of c relative to light, not a speed of 0 relative to light.
  • #81
Welcome to PhysicsForums, Mike.
This forum is intended primarily for mainstream discussions of physics topics. It is not intended for presentation of new theoretical ideas, which are normally presented in the context of peer-reviewed journals. Anyone is free to publish their ideas as they like on their own sites; that is what I do with my work (although most of my stuff is in fact mainstream).
And if you think this forum is devoted to Einstein, you haven't followed the discussions here sufficiently. There are skeptics here, but the presentation should be made within the context of legitimate topics. For example, SR and GR are currently generally accepted theories within the physics community. Therefore, a thread about why SR is wrong is not welcome here. On the other hand, EPR is considered to be outmoded (at least as to the incompleteness of QM) due to Bell's Theorem. Therefore, a critique of Einstein's position on this is acceptable.
Please keep in mind that there are many readers here with varying levels of knowledge. This forum is devoted to those interested in learning more about what is going on in physics and science.
Regarding your later post: I wonder why you don't feel the M/M experiment is good. Based on your historical description, how do you see that the speed of the air is an issue? Are you saying that the experiment would only be meaningful in a vacuum? Isn't the air itself also moving "faster" relative to the ether in the direction of the Earth's movement?
  • #82
You can do that by using a ruler :smile: That's the way we define length.
Under all conditions, even if you might question how we do know that the
ruler is always the same.
The example in the postscript shows that you get the same result under
various mixes of cx and cy components.
Regards, Hans
  • #83
Aether,
All Lorentz transforms are equally well valid. They are just different
representations of the same, single, reality. Just different 3D slices from
the single 4D universe.
What are you looking for? A preferred reference frame? what about Einstein's
beloved Machian reference frame, the center of gravity of all mass in the
universe. Or the modern day cosmologist's co-moving frame. more like the
center of mass of the local universe, so there are different co-moving frames
at different places in the universe.
Are you looking for aether? like your name implies. The vacuum is far from
empty. Look at the vacuums from Quantum Field Theory, All the many
different vacua people discuss in Quantum Gravity research. Just never
call it aether. That's a name which is reserved for a substance with a
classical gas like behavior. It has be shown over and over that that's
not the way how it works with incredible accuracy.
Are you maybe looking for the absolute "NOW" ?
Why should two different space/time events separated billions of light years
from each other be connected instaneously by an invisible link? You may
define a mathematical space in any arbitrary way that does so but does
it matter to physics anymore then a statement that two different events
have the same value for x or y? All what matters to physics is how different
events in space time communicate with each other, and they do so from
neighbor point to neighbor point to neighbor point. Two events at different
sides of the universe are completely disconnected.
Special Relativity holds up an illussion of a "NOW" in each reference frame
but in General Relativity there's no global "NOW" any more in any reference
frame.
Regards, Hans
  • #84
Hans de Vries said:
What are you looking for? A preferred reference frame? what about Einstein's beloved Machian reference frame, the center of gravity of all mass in the universe. Or the modern day cosmologist's co-moving frame. more like the center of mass of the local universe, so there are different co-moving frames at different places in the universe.
I'm working on a unification theory that makes predictions that are so precise and consistent that I tend to take them seriously, but a locally preferred frame seems to be implied. So, I raised the Aether flag and went forth to test the waters and found that LET is empirically equivalent to SR. Whether or not my own theory pans out, this empirical equivalence of LET and SR is something that I think people should be aware of.
Hans de Vries said:
Are you looking for aether? like your name implies. The vacuum is far from empty. Look at the vacuums from Quantum Field Theory, All the many different vacua people discuss in Quantum Gravity research. Just never call it aether. That's a name which is reserved for a substance with a classical gas like behavior. It has be shown over and over that that's not the way how it works with incredible accuracy.
Aether is used as shorthand for both a rarified gas (which is not how I am using it), and a locally preferred frame (which is how I am using it).
Hans de Vries said:
Are you maybe looking for the absolute "NOW" ? Why should two different space/time events separated billions of light years from each other be connected instaneously by an invisible link? You may define a mathematical space in any arbitrary way that does so but does it matter to physics anymore then a statement that two different events have the same value for x or y? All what matters to physics is how different events in space time communicate with each other, and they do so from neighbor point to neighbor point to neighbor point. Two events at different sides of the universe are completely disconnected.
This is getting close to where I'm going, that events on opposite side of the universe are connected instantaneously. Every event has a temporal coordinate on the farthest edge of the universe, so why shouldn't events be connected out there? There is cosmological evidence of such a link (e.g., the "horizon problem").
Hans de Vries said:
Special Relativity holds up an illussion of a "NOW" in each reference frame but in General Relativity there's no global "NOW" any more in any reference frame.
And, 98% of the matter-energy in the universe is still missing.
  • #85
Aether said:
I went forth to test the waters and found that LET is empirically equivalent to SR. Whether or not my own theory pans out, this empirical equivalence of LET and SR is something that I think people should be aware of.
Aether,
Mansouri & Sexl are plainly wrong with the claim that their Lorentz
Ether Theory is empirically equivalent to Special Relativity. There is only
one frame in which it makes some right predictions and that's the frame
in which they did their calculations: The preferred reference frame.
They then erroneously extrapolate that it does work in all the
reference frames.
In the other frames it gives results that are completely different than
those from Special Relativity. The LET is nothing else than a Galilean
transformation with a scaling factor (gamma)
A clear example in where it goes wrong is when you've got two objects,
one moving from left to right and the other from right to left, both with
the same speed. In SR both will have the same Lorentz contraction for
the observer at rest. In their LET however there is no such symmetry.
One object will typically get extended while the other gets contracted.
The only frame where LET and SR give equal results is in their preferred
reference frame.
It's only with the non-simultaneity of SR that two observers both
see each other contracted. With LET one observer will be contracted
and the other will be extended in an asymmetric way.
To see how SR works we can imagine that we instantaneously "freeze"
a bypassing traveler. Walking around him we can now see him "hanging
in the air", indeed being contracted in the direction in he was moving.
The traveler however will complain that his front was stopped first,
before his back was frozen, and argues that this is the reason of his
compressed state.
This now is a symmetric situation. If you'll lend you're "freezing device"
to the traveler then you'll see that you get frozen in the same way:
contracted by non-simultaneity.
With absolute simultaneity this will always lead to a paradox: If A is
contracted in respect with B. Then B is extended relative to A.
It is the non-simultaneity of SR which resolves this paradox.
Regards, Hans
P.S: R.Mansouri and R.U.Sexl
A Test Theory of Special Relativity, I. Simultaneity and Clock Synchronization
General Relativity and Gravitation, Vol 8, No 7 (1977) pp. 497-513
  • #86
Hans de Vries said:
Mansouri & Sexl are plainly wrong with the claim that their Lorentz Ether Theory is empirically equivalent to Special Relativity. There is only
one frame in which it makes some right predictions and that's the frame in which they did their calculations: The preferred reference frame.
Are Kostelecky&Mewes wrong too, http://www.citebase.org/cgi-bin/citations?id=oai:arXiv.org:hep-ph/0205211 , and everyone else over the past 28 years who has cited M-S without mentioning that they are "plainly wrong" about anything other than a few typos? Otherwise, let's assume that M-S are 100% right.
The asymmetrical length contractions that you see are balanced by an anisotropic speed of light. The point is, Hans, that any difference between the predictions of SR and LET are merely the result of coordinate choice rather than Lorentz symmetry. The two theories are empirically equivalent; any difference that you see is in the interpretation of the measurements and not in the measurements themselves.
Some people here already knew this, and some people here have only just realized this. The fact that some people are still struggling with it proves that it isn't a trivial point, and more care needs to be taken with the teaching of relativity: Local Lorentz symmetry is proven by experiment (up to a point, the search for violations of this symmetry are still ongoing), but special relativity per se is not even a valid subject for experiment.
  • #87
This is misleading. The M&S paperer is referred to because of the
parameterization scheme for possible deviations of Special Relativity.
It's only you who uses it to promote your ether theory.
The math of M&S is correct in the preferred frame, not in any other.
Aether said:
Some people here already knew this, and some people here have only just realized this. The fact that some people are still struggling with it proves that it isn't a trivial point, and more care needs to be taken with the teaching of relativity: Local Lorentz symmetry is proven by experiment, but special relativity per se is not even a valid subject for experiment.
Do you at all read my post? do you look at my examples. No you don't
SR is the ABC of physics. Something you have to understand pretty
well before you can start to learn some real physics. The examples I
gave are the simplest it gets in understanding the basic mechanisms in SR
and the simplest way to show that your Ether theory with absolute time
can never work.
Now try to do the math. Try to understand the physics. Don't just rely on
some statement you have found somewhere in a paper. It's now time for you
to prove your ether theory by actually showing how it can account for
these relativistic effects.
1) How can two observers both see the other in a Lorentz contracted state?
2) How can you rotate the deBroglie wavefronts of particles if you go from
one reference frame to another in order to keep them at right angles with
the direction of their speed? How can a single transformation rotate these
wavefront at all kinds of different angles depending on the speed of the
particles?
Let's see if you can do that without non simultaneity.
People here are willing to help others to get ahead. That's why it's called a
Physics Help and Math Help forum. But if there's no response and you just
keep repeating a statement from somewhere then things get pretty useless
after a while. I did the work, the math, the physics, showed you the images
from my simulations.
Now it's up to you.
Regards, Hans.
  • #88
Hans de Vries said:
Mansouri & Sexl are plainly wrong with the claim that their Lorentz Ether Theory is empirically equivalent to Special Relativity. There is only one frame in which it makes some right predictions and that's the frame in which they did their calculations: The preferred reference frame. They then erroneously extrapolate that it does work in all the reference frames.
Don't forget to reset your clocks: "where we have chosen to readjust our clocks according to [tex]f(x,v)=-vx[/tex]" -- Eq. 3.5 M&S-I p. 502
Hans de Vries said:
This is misleading. The M&S paperer is referred to because of the parameterization scheme for possible deviations of Special Relativity. It's only you who uses it to promote your ether theory.
You can't legitimately claim that M&S is plainly wrong, that they erroneously extrapolate, and also that I am misrepresenting their papers to promote my own theory. My own theory has nothing to do with this other than it motivates me personally to care about this particular issue.
Hans de Vries said:
Now try to do the math. Try to understand the physics. Don't just rely on some statement you have found somewhere in a paper. It's now time for you to prove your ether theory by actually showing how it can account for these relativistic effects.
M&S and every paper on local Lorentz invariance since then that quotes them is my proof. If they really are "plainly wrong" as you claim, then I'll have to go back to the drawing board. I don't mind working some transformation problems using the M&S papers as a guide to try and show that I am not applying their work improperly. You start by showing the Lorentz transform (Eq. 3.4 from M&S-I p. 501) for any example you choose (M&S restricts their examples to motion along the x-axis, so we will need to agree to do the same), and I will show the corresponding LET transform (Eq. 3.6 from M&S-I p. 502). "This transform is--as far as the prediction of experimental results is concerned--completely equivalent to (3.4)". -- M&S-I p. 502.
Eq. (3.4)
[tex]t=(1-v^2/c_0^2)^{1/2}T-vx[/tex]
[tex]x=(X-vT)/(1-v^2/c_0^2)^{1/2}[/tex]
Eq. (3.6)
[tex]t=(1-v^2/c_0^2)^{1/2}T[/tex]
Eq. (3.5) [tex]f(x,v)=-vx[/tex]
"We shall investigate here how the results of various experiments, which are usually considered to be tests of special relativity, can be interpreted using [3.6]. The transformation [3.6] is the very relation one would write down if one has to formulate an ether theory in which rods shrink by a factor [tex](1-v^2/c_0^2)^{1/2}[/tex] and clocks slow by a factor [tex](1-v^2/c_0^2)^{1/2}[/tex] when moving with respect to the ether. Note that [3.6] implies the existence of absolute simultaneity since [tex]\Delta T=0[/tex] implies [tex]\Delta t=0[/tex]. We thus arrive at the remarkable result that a theory maintaining absolute simultaneity is equivalent to special relativity." -- M&S-I p. 503
  • #89
That's true for an object stationary relative to the observer. For a moving object you must also read a clock, attached to the ruler at the point where the measurement is made.
If you say that two distances are the same, you must mean either they are both constant or else that they were both measured at the same time. So it depends of your definition of simultaneity.
  • #90
The one-way speed of light
Aether said:
Eq. (3.6)
[tex]t=(1-v^2)^{1/2}T[/tex]
[tex]x=(X-vT)/(1-v^2)^{1/2}[/tex]
"We shall investigate here how the results of various experiments, which are usually considered to be tests of special relativity, can be interpreted using [3.6]."
That should clear up a lot of confusion. OK. Let's see you compute the one-way speed of light.
Here's the experiment. In an arbitrary frame of reference in the aether model, start with two synchronized clocks side-by-side and slowly transport one of them to any convenient distance D. Then compute D/(t2-t1). The answer better be c. (t1 is the time on the stationary clock when the light pulse is sent. t2 is the time when the light arrives as measured by the slowly transported clock. Take the limit of ultraslow transport for a perfect answer of c).
  • · Replies 33 ·
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 74 ·
  • · Replies 57 ·
  • · Replies 45 ·
