jd1828af
- 1
- 0
Can anyone explain how pseudopotentials are calculated using density functional theory?
The discussion revolves around the calculation of pseudopotentials using density functional theory (DFT) and related computational methods. Participants explore various references, methodologies, and challenges associated with obtaining and utilizing pseudopotentials in computational physics.
Participants express varying levels of understanding and approaches to calculating pseudopotentials, with no consensus on specific methodologies or the best practices for ensuring accuracy in calculations. Some participants agree on the importance of benchmarking and using reliable pseudopotentials, while others raise questions about the adequacy of certain methods.
Limitations include the dependence on specific software for obtaining pseudopotential files, the need for careful selection of exchange/correlation functionals, and the unresolved nature of the best practices for convergence testing in large systems.
This discussion may be useful for researchers and students involved in computational physics, particularly those working with density functional theory and pseudopotential calculations.
Consult this : Bachelet, G. B. et al. (1982) Phys. Rev. B 26 4199jd1828af said:Can anyone explain how pseudopotentials are calculated using density functional theory?
jd1828 said:does anyone know of where I could find some calculated pseudopotentials for a solid. Ill go for just about any solid, although CO2 is what I would really need. I am just trying to see if my calculations are anywhere close to what they should be.
marlon said:CO2 a solid ?
I do not understand how you can check your calculations without having the pseudo potential file to model the [valence electron] <---> [nucleus + core electrons]-interactions ?
How exactly do you procede ?
I mean, assuming you are doing Hartree Fock or DFT calculations :
1) what software are you using ? Usually, the pseudopotential files (like the ) can be found on the server of the software developer ; like in the case of SIESTA or ABINIT.
2) What basis set are you using (like doubble zeta gaussians) or do you procede with plane waves ?
3) In DFT case, what approximation do you use for the exchange/correlation functional ? LDA, GGA, Hybrid models ? For metals, you must use the LYP-correlation functional of Parr et al (1988) together with the PBE exchange functional of Perdew, Burke and Ernzerhof (1996)
4) Normally, here you would chose your pseudo potential file. If you take one from literature, be sure that it is "transferable". Also, remember that the pseudopotential file that you choose will be partially determined by your exchange/correlation functional. You need to do a lot of benchmarking to get the right one.
The mentioned functionals can all be found in the previous references that i gave you.
marlon
That's a classic problem. Your atomic forces are too big. Normally the threshold (international standard) is below 0.05 eV/angström. To acquire this demand you must perform a atomic position relaxation and a atomic lattice relaxation.jd1828 said:I was getting very strange energies which I found was caused by the cell volume being a little too small.
marlon said:Just to be complete, let me again show you the general way to proceed after you have selected all necessary input data (pseudo potentials, exchange correlation functional, atomic lattice and atomic positions)
1) perform a convergence test with respect to the energy cutoff value
2) perform a convergence test with respect to the selected k-mesh. The bigger the unitcell, the smaller the k-point mesh (due to the inverse connection between Wigner Seitz unit vectors and (reciprocal) Brillouin unit vectors).
