Thread Closed
Definition of ESP
Share Thread Thread Tools
Oct28-03, 01:30 AM   #1
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Definition of ESP
So as not to hijack Zooby's thread "Eyes in the back of your head", I am posting this in a new thread.
Originally posted by zoobyshoe
[B]I said "denotation and connotation." The denotation of "Vain Seeking" is quite different than the denotation of "Ivan Seeking"
The authentic "sixth" sence has been well know to mankind since time immemorial. It our sence of balance. We use it all the time every day. The physical organs responsible for our sence of balance are located in the structures of the inner ear. It is an authentic, physical sence. It is not ESP. I suspect it was left out of the list because it lacks the on-off quality that help us recognize the other sences. If we put our hands over our ears sound is deadened, if we lift our hand from the table we can no longer touch it. If we leave the rose bed, it's smell stays behind, after we're done eating, the taste of the food goes away eventually, shut your eyes and you can't see. Balance can't be turned off like this. This makes it somewhat harder to recognise.
Our physical sense of balance is tied to our sense or hearing...but I think it really comes under our sense of touch.
How We Balance - The Vestibular System
The semicircular canals and vestibule function to sense movement (acceleration and deceleration) and static position. The three semicircular canals lie perpendicular to each other, one to sense movement in each of the 3 spatial planes. At the base of the canals are movement hair cells, collectively called the crista ampullaris. Depending on the plane of movement, the endolymph flowing within the semicircular canals stimulates the appropriate movement hair cells. Static head position is sensed by the vestibule, specifically, its utricle and saccule, which contain the position hair cells. Different head positions produce different gravity effects on these hair cells. Small calcium carbonate particles (otoliths) are the ultimate stimulants for the position hair cells.
The hair cells for both position and movement create nerve impulses. These impulses travel over the vestibular nerve to synapse in the brain stem, cerebellum, and spinal cord. No definite connections to the cerebral cortex exist. Instead, the impulses produce reflex actions to produce the corrective response. For example, a sudden loss of balance creates endolymph movement in the semicircular canals that triggers leg or arm reflex movements to restore balance.
http://webschoolsolutions.com/patts/systems/ear.htm
The prefix "extra-" means "outside" or "beyond" . It is not synonymous with the adjective "extra" which means "more than is due, usual, or necessary". Important distinction.
I hope I have just shown why the latter assertion is not true and why pheromones cannot be considered ESP.
I maintain this is just a matter of how we choose to define things. I think it has always meant the senses that we currently acknowledge.
ESP, in fact, denotes perception by means beyond or outside the sences; the connotation being: "inexplicable in any conventional terms - resulting from forces and energies outside those known to physics."
I have never seen this as the definition...this only serves to make ESP impossible by definition. If we find a new sense, one that explains previously unsubstantiated claims, then this is what we have always meant.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Oct28-03, 03:59 PM   #2
Mentor
So how would YOU define ESP? I would define it as any sense unrelated to our 5 known senses. Typical examples are telepathy, clarvoyance, 'mind over matter' (teleportation?), etc.
You may have already answered it, but this confused me:
edit: http://dictionary.reference.com/search?q=esp
Communication or perception by means other than the physical senses.
As I am a big fan of unambiguous definitions, I hate (even though I use sometimes) the phrase "your definition" or "my definition." This is THE definition.
Oct29-03, 12:24 AM   #3
Originally posted by Ivan Seeking Our physical sense of balance is tied to our sense or hearing...but I think it really comes under our sense of touch.
Balance is completely unrelated to hearing. People born stone cold deaf still have balance.
Balance is intimatly tied to vision. I emphasise tied because , although they are almost always working in close conjunction, one is not a subset of the other.
Touch is processed in the sensory strip located at the front of the parietal lobes.(Cerebral Cortex) As you pointed out balance is processed elsewhere. You are reasoning from the process whereby the sensitive hairs are "touched" by the inert otoliths when we move our heads, to call "balance" part of touch.
I think by the same logic we can call hearing a part of touch since it depends upon the eardrum being physically impinged upon (touched) by compression waves in the air. This makes sence since we can actually feel these compression waves with the touch receptors in our skin when the amplitude is high enough (powerful sound systems) So, actually we've only had four sences all along.
Course, I'm being facetious. The truth is that when we start parsing sences into their component clauses it turns out each thing we call a sence is a conventionalized name for what is, in fact, an aggregate of sences. Touch breaks down into sensation of pressure, sensation of cold, sensation of heat, sensation of pain, etc. Most of these are processed in the sensory strip, but with different circuits for each. Pain never goes to the sensory strip, but is processed in the thalami.
The list of the five sences is pretty much meaningless in scientific terms. It is a non-scientfic convention. However you define balance it is never included in the list of the sences, not because people are mistaking it for touch, but because people are not noticing it when they speak of the sences.
I still haven't brought up proprioception: the seventh sence; also not ESP.
You are correct, sir. The term ESP is very unfortunate because when properly examined it has no meaning. In order to discuss these phenomenon it is going to be necessary to refer to them with different, more accurate terminology.
I more or less agree except that in addition to being denotationally challenged, the term ESP has been the particular favorite of people who like the "inexplicable" connotations.
Occam's Razor dictates that if we prove the existence of a previously disagreed about ability we must first look for its explanation in terms of known quantities. If we don't; it's a free-for-all. My theory of Aetheric vibrations is as good as your theory that life is The Matrix.
I think Persinger has provided the best place to start looking, if such a thing were ever to be proven, without having meant to: it could be, if some non-ordinary perception were proven to exist, that people are very much more sensitive to run-of-the-mill EM waves than we realized. Or, perhaps we can hear in the ultrasonic range without having any conscious knowlege of it, like Hypnagogue's people with blindsight, who don't consciously realize they can see.
Oct29-03, 02:07 AM   #4
Recognitions:
Definition of ESP
I thought that this meant the five [6...7...Zooby are you done yet?] senses. When I checked sense however, there is a more general definition.
sense ( P ) Pronunciation Key (sns)
n.
a) Any of the faculties by which stimuli from outside or inside the body are received and felt, as the faculties of hearing, sight, smell, touch, taste, and equilibrium.
b) A perception or feeling produced by a stimulus; sensation: a sense of fatigue and hunger.
Zooby,
By definition b, when you're right, you're right. [6)]
Therefore, ESP refers to information and "powers" that operate outside of the laws of, and all future laws of physics.
I have never considered any such a claim to exist. Therefore, if any of these are possible, telepathy, clarvoyance, 'mind over matter' (teleportation?), etc. they may or may not be due to ESP.
Russ, does God operate outside of the laws of physics?
Oct30-03, 12:33 PM   #5
Mentor
According to the Christian version, he must.
Oct30-03, 01:46 PM   #6
Zooby,
I've been pondering this for a while and don't understand why definition b. strikes your fancy.
This sounds like a syllogism, the first two lines of which I didn't get to hear.
I'm sencing you want to hold onto the term, even if you have to change the meaning. I think it was a badly coined term to begin with, and something more accurate should be found.
Actually Fz+ made much the same point in another one of your threads somewhere.
Or, they may or may not be due to the Matrix, or anything you might care to speculate the cause to be. One theory is that spirits carry messages from mind to mind.
Funny kinda question.
Oct30-03, 04:27 PM   #7
Recognitions:
First of all, that we have only five senses is folklore, scientists have identified others - post a query on the Biology board and someone will be sure to have a list. One I remember is proprioception, the sense of where your body is, and how its parts are arranged. This is the sense that you use when working on a screw or something like that behind a barrier so that you can't see it. There's nothing mystical about it.
Second, when Rhine or whover invented the term ESP it was intended to refer to talents and powers of perception beyond what the known senses give. So the theory that your feeling when someone stares at you from behind is due to perceiving pheromones would be an explanation of an ESP capability and if accepted and validated would add a sense to the list ans subtract a talent from the ESP list.
Oct31-03, 12:39 AM   #8
Mentor
Yeah, I was kinda wondering where that came from too.
Oct31-03, 03:12 AM   #9
Recognitions:
Definition "a" is specific enough that I would still debate the point. But "a perception or feeling produced by a stimulus" is general enough so as to include any newly discovered abilities that may or may not be considered a sense.
This sounds like a syllogism, the first two lines of which I didn't get to hear. I'm sencing you want to hold onto the term, even if you have to change the meaning. I think it was a badly coined term to begin with, and something more accurate should be found.
You seem to ignore the more popular mystical interpretations of these claimed phenomena.
You're missing the point. We don't KNOW that all phenomenon can be explained using physics. I think so; it seems that you do also, and I'm sure that most people here would, but this is an assumption. If such a thing existed, what would we call "non-physical mind reading" for example? Some people believe in this sort of thing; perhaps even in the case of prayer by some beliefs, so a name would be nice. It seems to me that the tradional interpretation of ESP fits rather well.
Oct31-03, 03:21 AM   #10
Recognitions:
I completely agree. My orignal use of the term makes a point. If we find some of these things are true, then the true believers deserve to say I told you so; and that there be no confusion that they did.
Of course, I don't mean you personally. [:D]
Oct31-03, 04:36 AM   #11
That's correct when you are in the same place, since pheromones are airborne chemicals. But not for staring or observation from a separate room.
The term: proprioception, thanks didn't knew that sense was described.
Oct31-03, 05:32 AM   #12
Now I understand what you were thinking.
Originally posted by Ivan Seeking Therefore, ESP refers to information and "powers" that operate outside of the laws of, and all future laws of physics.
To which I responded:
Originally posted by zoobyshoe This sounds like a syllogism, the first two lines of which I didn't get to hear.
I later realized why what you said sounded like the last line of a syllogism: you were addressing the title of this thread: proffering the definition the thread was set up to ask about.
Strangely, though, you responded:
"I think so", is not an assumption. More like a tentative stance that doesn't seem rigidly opposed to change. I don't think we have to be on guard against an "I think so" perspective.
What I want to emphasize is what I said earlier:
Originally posted by zoobyshoe Occam's Razor dictates that if we prove the existence of a previously disagreed about ability we must first look for its explanation in terms of known quantities. If we don't; it's a free-for-all. My theory of Aetheric vibrations is as good as your theory that life is The Matrix.
Let's prove the ability. Then look for it's explanation in terms of known quantities, then, and only then, start looking elsewhere.
What will call it, if it is ever demonstrated to exist, is completely dependent on what we end up discovering about it.
This discussion got started when it came to light that you were ready to apply the term ESP to any hitherto unrecognized sence that might be proven to exist. My response was that information coming in through the sences can't properly be called "extrasensory". I am not arguing for or against the existence of any hitherto unrecognised ability. I am arguing for the accurate use of words. The inaccurate use of words is often a sign of, and also a propagator of, unclear thinking.
Oct31-03, 06:11 AM   #13
Please see my post above: 10-28-2003, 10:24 P.M. Where I went into the misconception that we only have 5 physical sences in detail.
Oct31-03, 01:30 PM   #14
Recognitions:
Absolutely. I never meant to imply otherwise. Also, I prefer the word investigate, as opposed to prove.
I understand your objection. I don't mean to assign credibility to a concept by giving it a name, but since we have two distinctly different approaches to mysticism - one that looks to science, and another that looks to more ethereal explanations - I was really trying to make the distinction by retaining the ESP designation.
In the case of scientific investigations of claimed phenomenon, I am glad to agree that the term ESP has no meaning and does not apply.
EDIT: Considering the education that I am getting about the senses, I suggest the designation YASP - Yet Another Sensory Perception. [:D]
Thread Closed
Thread Tools
Similar Threads for: Definition of ESP
Thread Forum Replies
Definition of d(a^x)/dx General Math 3
definition Differential Equations 0
would like a definition General Physics 3
