Calculate the density of plutonium
  • Thread starter Thread starter kidia
    Density
To calculate the density of plutonium, one cannot use the standard gas volume of 22.4 L, as plutonium is a solid at standard temperature and pressure (STP). Instead, the density calculation requires the lattice parameter and the molar mass, which must be converted to appropriate units (kg or grams). The crystal structure of plutonium is monoclinic, and the atomic radius is 175 pm (0.175 nm). The density can be expressed in either kg/m³ or g/cm³, depending on the unit system used. Understanding these parameters is essential for accurately determining plutonium's density.
kidia
I want to calculate the density of plutonium,which has molar mass of 244 and atomic number 94.my problem is the volume can I use the standard volume of gas molecule 22.4?
One cannot use the gas volume, 22.4 l, which is for a gas at STP. Plutonium is a solid at STP conditions.
Normally one would use a lattice parameter and the molecular mass (in amu) would need to be converted to kg is one is using SI or MKS units, or grams if one uses cgs. The lattice parameter (interatomic spacing) would have to be in the appropriate units.
Density could be in kg/m3 or g/cm3.
plutonium
Please can you clarify more by explain to me how to get the volume of plutonium?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
