Thread Closed
Reynolds number
Share Thread
Nov15-05, 02:42 PM   #1
Reynolds number
Hi, this is going to sound very stupid.
Is Red the same as Re?
Its just that in some equations, I have Red, and then in others Re. It might not sound like much of a problem, but I'd really appreciate if someone could clear things up for me. Thanks!
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Nov15-05, 04:04 PM   #2
Recognitions:
Reynolds number with a subscript usually pertains to the RE with respect to a particular characteristic dimension of an object. For example, in a lot of problems looking at flows past flat plates, you will see [tex]RE_x[/tex] for the RE along the length of the plate measured from the leading edge of the plate. Perhaps the usage in your case is the flow past a cylinder or sphere.
Nov15-05, 04:07 PM   #3
ohh right. Diameter, that's what it stands for. Its pipe flow. Thanks!
Thread Closed
Similar discussions for: Reynolds number
Thread Forum Replies
Relating the Reynolds number to the Drag Coeffient Advanced Physics Homework 6
Reynolds number may have a similar effect to the Knudsen number Mechanical Engineering 0
The reynolds number equation, need help. General Physics 6
Friction factor on very very low reynolds number Mechanical Engineering 6
Higher Reynolds number? Mechanical Engineering 3
