Find Tension in String when Yo-Yo is Released
The discussion revolves around determining the tension in a string connected to a yo-yo, which consists of two circular masses linked by a hub. The problem involves concepts from angular kinematics and dynamics, particularly focusing on the forces and accelerations acting on the yo-yo when it is released.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to relate the tangential acceleration of the yo-yo to gravitational acceleration, questioning if their reasoning about the acceleration being equal to g is correct. Other participants discuss the relationship between tension, torque, and angular motion, while also exploring the implications of the yo-yo's rotation on the tension in the string.
Participants are actively engaging with the problem, raising questions about the assumptions made regarding acceleration and tension. There is a recognition of the complexity of the situation, particularly regarding the effects of rotation on tension, but no consensus has been reached on the correct interpretation of the forces involved.
Some participants express uncertainty about the initial conditions of the yo-yo, particularly regarding its rotation and how that affects the tension in the string. There are also references to the inertia of the combined masses, which may influence the discussion further.
amcavoy
Let's say you have a yo-yo that is constructed from two circular masses connected by a small hub. If the radius of the hub is r and the radius of the circular masses is R, how can I find the tension in the string when the yo-yo is released? Assume each circular mass has mass M and the hub is m.
I know a bit about angular kinematics and dynamics, but I am having trouble applying that here. I am going to take a guess here and say that the tangential acceleration (the magnitude) is g (9.8 m/s2). The reason I say this is because the yo-yo would have a downward acceleration of g had it not been connected to any string. Because the string is connected, an object on the perimeter of the yo-yo will accelerate in the tangent direction at the same rate as if the yo-yo was in free-fall. Is this reasoning correct? If so, I believe I can make more progess on the problem.
Thank you.
The tension, T, in the string is applying a torque, tau = Tr, where r is the radius of the hub.
Then tau = I.alpha
and a = alpha*R
where a is the tangential acceleration and R is the radius of the circular mass.
Edit: I is the inertia of the combined masses.
Edit2: correction to the expression for linear acceln.
Isn't the tension in the string T = 2Mg + mg ?
Am I right about the tangential acceleration though?
Thanks for the response.
Hmmm.
Not absolutely certain, but it doesn't seem right.
Your argument would apply to every point in the yo-yo, including diametrically opposite points. Your argument would give both those points a downward accln of g, but we know that they would would start to move in opposite dirns.!
I'm not absolutely sure about what I said about the Tension in the string - it being equal to 2Mg + mg.
Somehow or other it feels as though the rotation of the yo-yo would offset some of the string's tension.
However, at the start, there is no rotation, So there won't be any offset to the tension then, so (I think) the initial tension in the string is T = 2Mg + mg.
And, if that assumption is true, then you can quite easily show that the initial tangential accln isn't neccesarily g, but depends on I.
Of course points on opposite sides are traveling in opposite directions, but when I say "g," I mean the magnitude of the tangential acceleration (not caring about direction).
Thanks again Fermat.
  • · Replies 49 ·
10K
10K
18K
