How Accurate Is the Center of Mass Calculation for an Open-Top Cubical Box?
  • Thread starter Thread starter suspenc3
The center of mass (COM) for an open-top cubical box with edges of length 40 cm is calculated to be at coordinates (20 cm, 16 cm, 20 cm). The calculation involves determining the mass distribution along the x, y, and z axes, where the mass of the sides and the bottom of the box are considered. The derived formulas for COMx and COMz yield a consistent result of 20 cm, while COMy is adjusted to 16 cm due to the absence of the top face. This analysis confirms the accuracy of the center of mass calculation for the specified geometry.
  • Understanding of basic physics concepts related to center of mass
  • Familiarity with mass distribution calculations
  • Knowledge of coordinate systems in three-dimensional space
  • Basic algebra for manipulating equations
  • Study the principles of center of mass in irregular shapes
  • Explore the impact of varying mass distributions on COM calculations
  • Learn about the applications of center of mass in engineering and physics
  • Investigate advanced topics such as moment of inertia and its relation to COM
Students and professionals in physics, engineering, and mathematics who are interested in understanding the calculations and implications of center of mass in three-dimensional objects.
suspenc3
a cubical box has edges of length 40cm with an open top.
Find the x, y, z coordinates of The Centre Of Mass
in my head I cut the box along the x-axis to get this
(let m = the mass of one side of the box)
[tex]COMx=\frac{1}{M}\times(m1x1 + m2x2)[/tex]
[tex]COMx=\frac{1}{5M}(2.5M\times 40cm)+(2.5M\times 0cm)[/tex]
[tex]COMx=20cm[/tex]
[tex]COMy=(2a\times 40cm)+(3M\times 0)[/tex]
[tex]COMy=16cm[/tex]
[tex]COMz=\frac{1}{5M}(2.5M\times 40cm)+(2.5M\times 0cm)[/tex]
[tex]COMz=20cm[/tex]
Therefore [tex]COM=(20cm,16cm,20cm)[/tex]
You could also decompose the problem : the sides are equivalent to a 4m mass on the axis of symmetry. Then the bottom makes lowering of the CM by : l/2/5=l/10.
Which in your case l=40, hence the lowering from the center is 4cm, and because the center is at y=20, you get CM(y)=20-4=16cm which is the same result.
15K
  • · Replies 20 ·
13K
