Can a fluorescent light bulb be used as an electrical generator?
  • Context: Undergrad
  • Thread starter Thread starter Jdo300
    Generator Light
The discussion revolves around the concept of using a fluorescent light bulb as an electrical generator. Participants explore the mechanics of fluorescent bulbs, particularly the role of the ballast and the behavior of gas inside the bulb when ionized. The conversation touches on theoretical implications of power generation and the nature of current and voltage in this context.
  • One participant proposes that if the control coil in a fluorescent bulb were absent, both voltage and current might rise, potentially allowing the bulb to output more power than it consumes.
  • Another participant challenges this idea, asserting that a fluorescent bulb dissipates energy rather than generates it, emphasizing that increased current leads to increased power consumption, not generation.
  • A later reply clarifies the function of the ballast, explaining that it regulates current and voltage in the bulb, and questions the understanding of how current flows through the bulb.
  • Further contributions reference external sources to support claims about the behavior of gas in the bulb and the principles of inductance related to the ballast.
  • There is a discussion about whether the resistance of the gas decreases as more ions are created, affecting the voltage required to maintain current flow.
Participants express differing views on whether a fluorescent bulb can function as a generator. There is no consensus on the mechanics of current and voltage behavior in the bulb, and the discussion remains unresolved regarding the potential for power generation.
Participants reference various sources to support their claims, but there are unresolved assumptions about the behavior of the gas in the bulb and the role of the ballast in regulating current and voltage.
Jdo300
Fluorescent Light Generator??
Hi, I was recently reading up on the workings of fluorescent light bulbs, and I thought of an idea for using the bulb as an electrical generator. I know that inside the ballast of the light fixture, there is a small coil of wire that keeps the electrical current from going to fast through the bulb. I also learned that the gas inside the bulb itself, when excited with electrons, turns into plasma, which interacts with the phosphorous coating on the glass to make light. I also learned that unlike normal copper wires, when electricity flows through plasma, the resistance drops as the current rises because the excited ions continually release more electrons as the electricity flows through the gas. I was wondering if anyone knew if both the voltage and the current would rise inside the bulb if the control coil were not present to regulate the power flow. If both the voltage and current rise couldn’t one logically say that the bulb is outputting more power then it took to get it started? If this is true (and it’s purely hypothetical) couldn’t one create a circuit chip to keep the bulb lit and draw out the excess power instead of wasting it away in the control coil? I have absolutely no idea if this would work, but it was just an idea. Any thoughts?
Science news on Phys.org
A coil of wire? An inductor? This won't regulate current.
A fluorescent tube is nothing more than a tube full of low-pressure mercury vapor with electrodes on each end. When you pass current through the mercury vapor, the mercury atoms radiate ultraviolet light. The tube is coated with phosphor on the inside surface. The phosphor absorbs the UV light and radiates visible light.
I don't think you fully understand the way a fluorescent tube controller works. I also am not sure what copper coil you're talking about.
Forget about the voltage. What matters is the current. The more current passing through the vapor, the more light emitted. If the tube draws more current, it's using more power, turning that power into light. It does not make energy -- it dissipates energy provided by the plug you plug into a wall.
No, of course not.
- Warren
Ok, first off, thank you for your reply. Here is the link to the source I used to find the information I'm talking about:
http://home.howstuffworks.com/fluorescent-lamp4.htm
I included some snipplets from the article so you can see where I got my information from.
Here's the part about the gas in the bulb being a plasma:
This surge in current helps build the initial voltage needed to establish the electrical arc through the gas. Instead of flowing through the bypass circuit and jumping across the gap in the starter switch, the electrical current flows through the tube. The free electrons collide with the atoms, knocking loose other electrons, which creates ions. The result is a plasma, a gas composed largely of ions and free electrons, all moving freely. This creates a path for an electrical current.
And Here's another section of the article that explains how the coil in the ballast works:
In a gas discharge, such as a fluorescent lamp, current causes resistance to decrease. This is because as more electrons and ions flow through a particular area, they bump into more atoms, which frees up electrons, creating more charged particles. In this way, current will climb on its own in a gas discharge, as long as there is adequate voltage (and household AC current has a lot of voltage). If the current in a fluorescent light isn't controlled, it can blow out the various electrical components.
A fluorescent lamp's ballast works to control this. The simplest sort of ballast, generally referred to as a magnetic ballast, works something like an inductor. A basic inductor consists of a coil of wire in a circuit, which may be wound around a piece of metal. If you've read How Electromagnets Work, you know that when you send electrical current through a wire, it generates a magnetic field. Positioning the wire in concentric loops amplifies this field.
This sort of field affects not only objects around the loop, but also the loop itself. Increasing the current in the loop increases the magnetic field, which applies a voltage opposite the flow of current in the wire. In short, a coiled length of wire in a circuit (an inductor) opposes change in the current flowing through it (see How Inductors Work for details). The transformer elements in a magnetic ballast use this principle to regulate the current in a fluorescent lamp.
A ballast can only slow down changes in current -- it can't stop them. But the alternating current powering a fluorescent light is constantly reversing itself, so the ballast only has to inhibit increasing current in a particular direction for a short amount of time. Check out this site for more information on this process.
I understand that the bulb has to have a constant input of elecreicity to keep it running but I was wondering about the effect the plasma/gas has on the output electrical current. I want to know if both the voltage and the current are rising in the bulb or just the current due to less resistance.
Heres another refference that talks about the gas in the bulb being a plasma: http://www-istp.gsfc.nasa.gov/Education/wfluor.html
Thank you for your reply and I look forward to your response :smile:
Right, simply exploiting the fact that current through an inductor cannot change instantaneously.
Current in through one end of the tube = current out from the other. What 'output electrical current' are you talking about?
The falling resistance means a lower voltage is necessary to establish a given current. Since current is what matters for a gas-discharge tube, as more gas is ionized, the applied voltage will go down. This is part of of what a ballast does -- it provides a large starting voltage to establish an arc. Once the arc is established, the ballast reduces the voltage significantly, and begins regulating the current.
- Warren
  • · Replies 16 ·
  • · Replies 57 ·
15K
  • · Replies 30 ·
