How dangerous is it to ascend with expanding lungs?
  • Thread starter Thread starter erik-the-red
    Air Bubble Lake
The discussion revolves around the physics of gas behavior in relation to a diver's ascent in a lake, specifically focusing on the expansion of air bubbles and the implications for lung safety during ascent. The subject area includes principles of fluid mechanics and gas laws.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between pressure, volume, and temperature of gases using the ideal gas law. Questions arise regarding the appropriate starting point for calculations, particularly in relation to the height of the water column and the implications of holding one's breath during ascent.
Some participants have provided hints and guidance on using the combined gas law to relate the volumes at different pressures and temperatures. There is an ongoing exploration of the safety implications of holding one's breath while ascending, with differing views based on the type of diving being discussed.
Participants note the lack of specific height information and the potential differences in safety based on whether the diver is using compressed air or free diving. The discussion also touches on the risks of decompression sickness associated with rapid ascents.
erik-the-red
Question
A diver named Jacques observes a bubble of air rising from the bottom of a lake (where the absolute pressure is [tex]3.50 {\rm atm}[/tex]) to the surface (where the pressure is [tex]1.00 {\rm atm}[/tex]). The temperature at the bottom is [tex]4.0{\rm ^{\circ} C}[/tex], and the temperature at the surface is [tex]23.0{\rm ^{\circ} C}[/tex].
1. What is the ratio of the volume of the bubble as it reaches the surface ( [tex]V_s[/tex]) to its volume at the bottom ([tex]V_b[/tex])?
Well, I'm thinking [tex]P_b = P_s + \rho \cdot g \cdot h[/tex]. But, I don't know the height, so this may not be the right place to start.
Another thing I was thinking was [tex]\rho_{water} = \frac{m}{V} = 1[/tex] kg / L.
But, it seems like neither of these will get me started.
What is a good starting point for this question?
Hint: Treat the air in the bubble as an ideal gas.
The first thing that strikes me when I see this is: "Don't you know everything but the height?"
I would probably begin by trying to think of a principle (and corresponding formula, if appropriate) that would involve the volume of the bubble.
What possessed me to not realize that?
Thanks :redface:
I played on Doc Al's hint on treating the air in the bubble as an ideal gas. If so, this means I can use the combined gas law.
[tex]\frac{P_s \cdot V_s}{T_s} = \frac{P_b \cdot V_b}{T_b}[/tex].
From that, I get [tex]\frac{V_s}{V_b} = \frac{P_b \cdot T_s}{P_s \cdot T_b}[/tex].
Plugging in known values results in [tex]\frac{V_s}{V_b} = \frac{3.50 * (23.0 + 273.15)}{1.00 * (4.00 + 273.15)}[/tex].
This is 3.74. Is this correct?
OK, my answer is correct, after two very stupid answers :D
The second part of the question is:
Would it be safe for Jacques to hold his breath while ascending from the bottom of the lake to the surface?
The volume at the surface is almost four times the volume at the bottom. I think the answer is no. If he holds it in, the volume of air in his chest will expand, right?
That actually depends on what kind of diving Jaques is doing. If he's using compressed air of any kind (like SCUBA gear), then the answer is definitely no. If, on the other hand he's free diving then he could (mostly) get away with holding his breath. (A difference of 2.5 atmospheres corresponds to about 90 feet, which is quite feasible.)
Here is the answer
If Jacques were holding his breath, then air would be unable to enter or leave his lungs. As he ascends to the surface, the air in his lungs would expand, like the air in the bubble, and his lungs would have to stretch outward to hold this increased volume, which would be extremely unsafe.
In fact, even if he does not hold his breath, if he ascends too quickly after a particularly long or deep dive, the nitrogen dissolved in his bloodstream could form into small bubbles, which can be equally dangerous to any diver. This condition is known as decompression sickness, or more commonly as the bends.
jyeh1989107 said:
Here is the answer
A bit of an understatement there. :rolleyes:
The lungs can only stand an overpressure of about 25%. More will cause the alveoli (air sacs) will rupture and his blood will leak out into his pleura (the space between the lungs and the chest wall). And that's just the start...
