Finding Turbine Angular Velocity given Net Head, GPM, and power from Alternator.
The discussion focuses on calculating the angular velocity of a water turbine given specific parameters: an alternator generating 35 Watts at 50 feet of head and 10 gallons per minute, with an efficiency of 50%. To determine the angular velocity, additional information such as the average radius of the turbine blades is essential. The relationship between power, torque, and angular velocity is crucial for this calculation.
  • Understanding of basic physics principles, particularly power and torque calculations.
  • Familiarity with hydraulic systems and their efficiency metrics.
  • Knowledge of angular velocity and its relation to rotational systems.
  • Basic understanding of turbine mechanics and design parameters.
  • Research the formula for calculating angular velocity from power and torque.
  • Learn about the impact of turbine blade radius on performance metrics.
  • Explore the principles of hydraulic efficiency in turbine systems.
  • Investigate methods for measuring and optimizing turbine performance.
Engineers, hydropower technicians, and anyone involved in turbine design and optimization will benefit from this discussion.
MaxMoon
An alternator attached to a water turbine generates 35 Watts given 50 feet of head and 10 gallons per minute. Assuming that the efficiency of the alternator is 50%, is it possible for me to find the angular velocity from this information?
If so, how would I do it?
humm...im not sure if I am right but assuming your trying to find the angular velocity of the turbine blades? then i think you need more information such as average radius of the turbine where the blades are. But I am not even sure if your taking about that...
10K
