What Causes Difficulty in Understanding Chemistry?
  • Thread starter Thread starter gotzmlk
    Chem
This discussion focuses on the challenges faced in understanding chemical formulas and reactions, specifically regarding calcium carbonate (CaCO3) and copper sulfate (CuSO4). Participants explore the correct chemical formulas based on experimental results and discuss the formation of new solids and liquids during reactions. Key concepts include the determination of ratios in test tubes and the identification of precipitates formed in various chemical reactions.
  • Understanding of basic chemical reactions and stoichiometry
  • Familiarity with chemical formulas, specifically for calcium carbonate and copper sulfate
  • Knowledge of valence and how it applies to chemical compounds
  • Experience with laboratory techniques for observing chemical reactions
  • Research the process of determining chemical formulas through experimental data
  • Learn about the principles of stoichiometry in chemical reactions
  • Study the use of spectroscopy for identifying chemical compounds
  • Explore the properties and reactions of common compounds like sodium hydroxide and copper hydroxide
Chemistry students, educators, and laboratory technicians seeking to enhance their understanding of chemical reactions and formula determination.
gotzmlk
Hi, I am having a huge problem with chem. i do not know what the heck is going on so can i have some help.
Drops of each chemical into test tubes
ratios Ca:CO
test tube1: 0:24
test tube2: 1:5
test tube3: 1:2
test tube4: 1:1
test tube5: 2:1
test tube6: 5:1
test tube7: 24:0
Determining Chemical Formulas I
11. Based on valence, what do you think is the correct chemical formula for calcium carbonate?
CaCO3
12. Do your experimental results for the chemical formula for calcium carbonate agree with your chemical formula in question #11?
13. What is the name of the new solid formed in the reaction?
Salt
14. What is the name of the new liquid formed in the reaction?
15. Write the name of each of the compounds below the chemical equation, which shows what reaction, took place:
CaCl2 + Na2CO3 à 2 NaCl
_____________ _________________ __________________
16. If the correct formula for calcium carbonate had been Ca2CO3, which test tube would have contained the greatest amount of precipitate?
17. If the correct formula for calcium carbonate had been Ca(CO3)5, which test tube would have contained the greats amount of precipitate?
18. If the correct formula for calcium carbonate had been Ca(CO3)2, which test tube would have contained the greats amount of precipitate?
19. How could you experimentally determine the correct chemical formula for the new liquid formed?
20. How were the rations of calcium and carbonate determined?
ratios: Cu:OH
test tube1: O:24
test tube2: 1:5
test tube3: 1:2
test tube4: 1:1
test tube5: 2:1
test tube6: 5:1
test tube 7: 24:0
Determining Chemical Formulas II
1. List the elements and the number of atoms of each element in one molecule of copper sulfate?
2. How many different elements are in one molecule of copper sulfate?
3. How many total atoms are in one molecule of copper sulfate
4. What is the symbol and valence for copper II?
5. What is the formula and valence for sulfate?
6. List the elements and the number of atoms of each element in one molecule of sodium hydroxide?
7. How many different elements are in one molecule of sodium hydroxide?
8. How many total atoms are in once molecule of sodium hydroxide?
9. What is the symbol and valence for sodium?
10. What is the formula and valence for hydroxide?
11. Based in valence, what do you think is the correct chemical formula for copper hydroxide?
12. Do your experimental results for the chemical formula for copper hydroxide agree with your chemical formula in question #11?
CuCO4 + 2 NaOH à Na2SO4
16. If the correct formulae for calcium carbonate had been CuOH, which test tube would have contained the greats amount of precipitate?
17. If the correct formulae for calcium carbonate had been Cu2OH, which test tube would have contained the greats amount of precipitate?
18. If the correct formulae for calcium carbonate had been Cu(OH)5, which test tube would have contained the greats amount of precipitate?
19. How could you experimentally determine the chemical formula for the new liquid formed?
Chemistry news on Phys.org
what I can remember
please note, while my degree was in chemistry, its been a while and I am very likely to get them wrong!... will answer form what think I KNOW!
CuSO 4
-OH
its - 1
- 2 I THINK!
S04
Na
Na is plus one Na +1
Na only one
O only one
H only one
thus full formula
NaOH
tell me the product please?
most (carbon cont) chemicals can be tested using some forms of spectroscopy!
sorry don't have enough time...
24K
  • · Replies 16 ·
35K
  • · Replies 19 ·
11K
