Looking for a Budget-Friendly Solid-State Inclinometer?
  • Thread starter Thread starter dduardo
The discussion revolves around finding a budget-friendly solid-state inclinometer suitable for interfacing with a microprocessor to detect the angle of an LCD panel for orientation adjustments. Participants explore various options, including accelerometers, and share insights on specific components and their applications.
  • One participant seeks a low-cost single-axis solid-state inclinometer for use with a microprocessor.
  • Another participant suggests brands like Starett or Omega but expresses doubt about finding a "cheap" option with data output.
  • A participant mentions Apple's use of an inclinometer in PowerBooks for window orientation based on the device's tilt.
  • A participant identifies the ADXL322 from Analog Devices as a suitable component, highlighting its small size, low power consumption, and affordability.
  • Another participant reiterates the ADXL322's specifications and suggests purchasing directly from Analog to save costs.
  • One participant notes that the ADXL322 is not an inclinometer per se but acknowledges its effective application as an accelerometer for tilt detection.
Participants do not reach a consensus on the definition of an inclinometer versus an accelerometer, with some acknowledging the utility of accelerometers for tilt sensing while others seek a specific inclinometer solution.
The discussion reflects varying interpretations of the required sensor type and its applications, with some participants focusing on the technical specifications and others on practical usage scenarios.
dduardo
Staff Emeritus
Insights Author
Anyone know of a good and cheap single axis solid-state inclinomter? I want to interface the sensor with a microprocessor in order to know what angle a lcd panel has been rotated so I may adjust to portrait or landscape mode.
I don't know of any "cheap" ones with a data output. You might try Starett or Omega.
Apple has built an inclinometer into their PowerBooks and people have actually used as an input device to orient the windows depending on how the person is viewing the lcd.
http://en.wikipedia.org/wiki/Sudden_Motion_Sensor
The microcomputer that I'm using is the Gumstix and it very small (Literally the size of a stick of gum) therefore I need small components. I would think the solid-state route would be best in this senario.
I found the part I needed. It is the ADXL322 from Analog Devices.
http://www.analog.com/en/prod/0,2877,ADXL322,00.html
"The ADXL322 is an ultra small package (4 x 4 x 1.45 mm LFCSP) and low power (340 µA at Vs = 2.4V) ± 2g iMEMS® Accelerometer designed to accommodate the integration requirements of mobile phones and other portable devices for a variety of motion, tilt, and inertial sensing features (e.g., data entry, menu and display control, power management, situational awareness, navigation, and portrait vs. landscape display orientation). The ADXL322 also enables hard disk drive protection systems and security features in notebook computers, as well as position and tilt sensing for PC and gaming peripherals such as mouse and joystick devices."
It is also cheap: $8.33 at digikey
Analog is usually pretty good about selling in small quantities. I bet you could save a few bucks by getting them from Analog instead of digikey.
Here's and EDN article on accelerometers.
http://www.edn.com/article/CA472836.html
Ahhh...so it's not an inclinometer per-se. It is a great use of accelerometers though. You learn something new every day.
17K
  • · Replies 152 ·
12K
16K
11K
