What is its speed after traveling 1.00 m on the rough surface?
  • Thread starter Thread starter cc21392001
    Speed Surface
The discussion revolves around a physics problem involving a block sliding down a ramp and then moving on a rough horizontal surface, specifically focusing on calculating its speed after traveling a certain distance on that surface. The subject area includes concepts of energy, friction, and kinetic energy.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of energy calculations to determine the speed of the block after it travels 1.00 m on the rough surface. There are attempts to calculate the frictional force and the work done against friction. Questions arise regarding the understanding of the problem setup, particularly the frictionless nature of the ramp.
The discussion is ongoing, with participants providing hints and guidance on how to approach the problem. There is a recognition of the need to clarify the assumptions about the ramp and the rough surface, and some participants are exploring the implications of their calculations.
Participants note the importance of showing attempts at solutions as per forum guidelines. There is a mention of the specific conditions of the problem, including the rough surface and the friction coefficient, which are central to the calculations being discussed.
cc21392001
physics homework help ASAP thx!
thx so much, here they are:
48. A block of mass 0.6 kg slides 6.0 m down a frictionless ramp inclined at 20 degrees to the horizontal. It then travels on a rough horizontal surface where coefficient of kinetic friction is 0.50.
a) what is its speed after traveling 1.00 m on the rough surface?
b) what distance does it travel on this horizontal furface before stopping?
68. An electron moves with a speed of 0.995c.
a) what is its kinetic energy?
b) if you use the classical expression to calculate its kinetic energy, what percentage error would result?
k = mc^2((1/(1-(v/c)^2))-1)
thx a lot
Greetings !
First of all welcome to PF ! And, as a member, you should
know that there are certain guidelines in every forum
here and the main guideline of this forum is that you
have to show your attempt at a solution and not just
ask for one.
I'll give you some general hints though - in the first
question you'd better use energy calcs. Find the energy
at the bottom and think how you can compare it to the
energy lost due to friction on the surface.
In the second, well, just use the formula after you
understand what its parts mean. :wink:
Live long and prosper.
oh ok
well for the first one i found the frictional force that's retarding the energy of the object, so that's friction coefficient x normal force x distance, 0.5 x 0.6 x 9.8 x cos20 = 2.76, the distance is one.
then i subtract the total work which is 0.6 x 9.8 x 6sin20 = 12.07 with 2.76 and get 9.31 J. ok, now wut happens? i spent about 3 hours on this problem already, please help!
Correct, but that's happening on the horizontal part, not the ramp, right? Please redo.
OK.
You should use the formula for kinetic energy.
[tex] T = \frac{1}{2}mv^2.[/tex]
oh ok
well for the first one i found the frictional force that's retarding the energy of the object, so that's friction coefficient x normal force x distance, 0.5 x 0.6 x 9.8 x cos20 = 2.76...
The ramp is frictionless...
..., the distance is one.
You've spent 3 hours on it and still didn't realize the ramp is frictionless? Maybe your problem is English.
naw man the problem says "on the rough surface"
10K
