Schaum's Outline Study Guides: How Good Are They?
  • Thread starter Thread starter end3r7
The discussion revolves around the effectiveness of Schaum's Outline Study Guides as study aids for students, particularly in the context of physics and related subjects. Participants explore their utility for exam preparation versus deep understanding of the material.
  • Some participants assert that Schaum's books are very good for exam preparation.
  • Others suggest that while the books are useful for passing exams, they do not provide sufficient depth for a comprehensive understanding of the subject matter.
  • One participant notes that the Applied Physics book is an easy read and serves as a good review, but should not be relied upon as a primary text.
  • Another participant emphasizes that the series is effective for hands-on learning, focusing on problem-solving skills with minimal theoretical background, and suggests that they are best used alongside more theoretical resources.
  • It is mentioned that the series helps refresh practical skills for material previously learned, making it a valuable complement to theoretical courses.
Participants express mixed views on the effectiveness of Schaum's outlines, with some agreeing on their utility for exams while others highlight their limitations in fostering deep understanding. No consensus is reached regarding their overall value.
Participants note that the outlines reduce theory to a minimum, which may limit deeper insights into the subjects discussed.
end3r7
Generally how good are those books for a student to use as a study guide?
Very good.
They are good for doing well in the exams, but not good enough if you want to get some deep understanding.
I've got the Applied physics. It's an easy read, and a good review, but I wouldn't want it as a primary text.
They are quite good "to get your hands dirty". I have almost the entire series of everything that has to do with physics, electronics, engineering and chemistry and they all work along the same principle: learning by doing. Theory is reduced to the bare minimum, just enough to make sense of the problem-solving algorithms that are presented, then a series of detailled worked-out problems ("case studies" if you like), and then a set of similar problems, but with only the final answer to check if you got it or not.
As said before, they don't give you deep insight in the theoretical aspect of the matter (and thus not a very deep understanding) - you better get that in parallel elsewhere. But they give you a very robust set of problem-solving skills in the matter. Don't think that these are "cheap tricks", no, you get a systematic education in problem solving which is really really useful.
The best use for the Schaum series is:
- as a practical complement to a theoretical course
- when you have learned some material long ago, remember that you understood it, but you've a bit lost your practical skills, to get you up and running again.
  • · Replies 16 ·
10K
  • · Replies 0 ·
  • · Replies 26 ·
10K
  • · Replies 27 ·
