Find Resources for Modeling Generic CEV Re-Entry
Modeling a generic Crew Exploration Vehicle (CEV) re-entry involves significant challenges, particularly in obtaining accurate mass properties like drag coefficients and initial velocity. Atmospheric drag becomes significant around 50 km altitude, and an optimal re-entry angle is between 2 and 4 degrees. Numerical simulations for hypersonic flows are complex and often require advanced computing resources, making them impractical for simple models. For basic modeling, approximations for weight, surface area, and thrust forces can be sourced from existing aerospace literature or NASA databases. Accurate data is crucial for effective modeling, especially when simplifying the scenario to a straight vertical descent.
schemp98
Hello,
I need to model a generic CEV re-entry, and was wondering if anyone could guide me towards a resource for mass properties (drag coefficients, mass, inertias, initial velocity, etc). Thank You
Shaun
Ugh. I hate to say it, but that is not a trivial thing to do.
I was doing a design project my senior year, and we 'broke' two different FEM programs trying to model it (fluent and femlab). Neither were designed to handle hypersonic flows. We ended up waving our hands and saying "we're going to assume that it works" based on the expertise of our advisor and shapes of the Apollo and Gemini reentry vehicles.
It was a long time ago, so I'm going from memory with this info:
You start getting significant atmospheric drag around 50km. We were told that you'd want to have a reentry angle of between 2 and 4 degrees from circular. One of the guys in my team did the orbital dynamics to determine what sort of burn we needed using a one sided hohmann transfer and calculated our entry velocity at that point. We pulled atmospheric densities off of a NASA site and curvefitted it. We were originally going to try to do an ODE simulation using MATLAB before we gave up to focus on other sections of the design (only so much you can do for a one semester course with a 8-person team).
schemp98 said:
Hello,
Shaun
I would say it is pretty impossible to obtain accurate data if you want to compute it numerically. Ok, maybe you are able to simplify the reentry and watch your CEV as a point falling on Earth if the only thing in which you are interested is on the large scale kinematics of the vehicle. A numeric flow simulation is out of scope if you are not using a supercomputer. Take into account that the Reynolds# as such altitudes may be of the order of 10 millions. Personally, I made a numerical simulation of the reentry flow of a CEV sometime ago (Enigma knows about my simulation), with M=4.52 and Re=1250, which is pretty unrealistic.
Thanks for your replies, I think I should have elaborated on my situation...
Right now, I just need to create a simple model of a CEV falling straight down (with some neglible horizontal velocity)
I already have a 'skeleton' of a model up and running. Basically, I just need to find physical characteristics such as weight, surface area w/ and w/o parachutes open, and forces of the thruster (approximations are fine).
Any ideas on where I could easily find this stuff? Thanks
Shaun
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
