Finding current problem, where did i mess up?
  • Thread starter Thread starter mr_coffee
    Current
The discussion centers on the calculation of induced electromotive force (emf) and current in a conducting rod moving through a magnetic field. The rod has a length of 10 cm, moves at a velocity of 7.7 m/s, and is subjected to a magnetic field of 1.9 T. The correct induced emf is calculated as 1.463 V. However, the user incorrectly calculated the current as 3.6575 A due to a misunderstanding of the direction of current flow, which should be clockwise, resulting in a negative value when counterclockwise is considered positive.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Knowledge of Ohm's Law (V = IR)
  • Familiarity with the right-hand rule for determining current direction
  • Basic concepts of magnetic fields and their effects on conductors
  • Study Faraday's Law of Electromagnetic Induction in detail
  • Learn about the right-hand rule and its applications in electromagnetism
  • Explore the relationship between velocity, magnetic field, and induced emf
  • Investigate circuit analysis techniques involving resistive components
Physics students, electrical engineers, and anyone interested in understanding electromagnetic induction and circuit analysis.
mr_coffee
The conducting rod shown in Figure 30-52 has a length L and is being pulled along horizontal, frictionless, conducting rails at a constant velocity v. The rails are connected at one end with a metal strip. A uniform magnetic field B, directed out of the page, fills the region in which the rod moves. Assume that L = 10 cm, v = 7.7 m/s, and B = 1.9 T.
Here is the picture:
http://www.webassign.net/hrw/hrw7_30-52.gif
(a) What is the magnitude and direction of the emf induced in the rod? (Take up to be positive.)
I got: 1.463 which was correct.
(b)What is the magnitude and direction of the current in the conducting loop? (Take counterclockwise to be positive.) Assume that the resistance of the rod is 0.40 OHMS and that the resistance of the rails and metal strip is negligibly small.
I used
EMF - IR = 0;
I = EMF/R;
I = 1.463/.40 = 3.6575 which was wrong, any ideas were i messed up? Thanks.
The positive charges in the rod, moving to left, are pushed UPWARD
(by the right-hand-rule, okay?), which is in the CLOCKWISE sense.
If COUNTER-clockwise is called positive, your current will be negative.
Ahh thank you lightgrav!
  • · Replies 22 ·
