What is B16 and How Does it Compare to 10.9 and 12.9 Bolts?
  • Thread starter Thread starter brewnog
    Terms
The discussion revolves around the properties and comparisons of B16 bolts in relation to 10.9 and 12.9 bolts. Participants explore the metallurgical standards, strength, and applications of these different bolt grades, as well as practical considerations for clamping force in specific applications.
  • Experimental/applied
  • Some participants identify B16 as an alloy steel designation per ASTM A 193, used in piping and pressure vessel systems.
  • Others mention that B16 bolts have specific yield and ultimate strengths, with B16 being significantly weaker than grade 12.9 bolts.
  • One participant suggests that a weaker bolt may provide more clamping force due to increased stretch, while another counters that a stronger bolt will stretch more due to higher tensile stress.
  • There is a discussion about the torque capability of Allen keys and the factors affecting their performance, including material strength and friction with the screw head.
  • Participants express uncertainty about the availability of cross-references for B16 in existing standards and the implications of using different bolt grades.
Participants generally agree on the classification of B16 as an alloy designation and its relative strength compared to 12.9 bolts. However, there is disagreement regarding the implications of using a weaker bolt for clamping force, as well as uncertainties about the torque capabilities of Allen keys.
Limitations include the lack of consensus on the practical implications of using B16 versus 10.9 or 12.9 bolts, and the absence of published torque specifications for Allen keys. The discussion also highlights the dependence on specific application contexts and material properties.
brewnog
Bolts.
I have an application where I need some more clamping force (currently got 12.9 capscrews), can't find any 10.9's, but have a load of B16's lying around.
Any idea what B16 is, in terms of bolts? I'm pretty sure it's some kind of metallurgical standard, definitely not a size or thread pitch or anything like that.
Would I be able to compare B16 to, say, 12.9 or 10.9, or would that be apples and oranges?
Help!
Are there any markings on the heads or are they SHCS?
EDIT: B16 is an alloy steel designation spec. I'm seeing if I can find it anywhere. BRB.
Well, I have searched high and low. I think I may be at a disadvantage here. I did find one reference to it on this site:
http://www.hevilifts.co.uk/products/studs_bolts
Maybe you can give them a call and talk to one of their applications engineers for the spec title or something you can search on.
Hi Brewnog. As Fred says, the B16 is an alloy designation. It's actually the grade of the material per ASTM A 193. These bolts are often used in ASME related piping or pressure vessel systems.
B16 is a ferritic steel with alloying elements that include chromium, molybdenum & vanadium in addition to the more common ones such as carbon. Both the ASTM spec and ASME B31.3 lists the yield strength at 105 ksi, ultimate 125 ksi and in metric units it lists as 725 MPa yield, 860 MPa ultimate.
Looks like you're stuck with your grade 12.9 which is significantly stronger.
Cheers chaps.
I was actually trying to find a weaker bolt, to stretch it more and get more of a clamping force between my two things to be fastened. We'll see...!
I'll chase up those links, thanks guys.
Q, did you have any kind of cross reference on that ASTM spec or is that from experience? I couldn't find any ANSI or ASTM specs that listed the B16.
Hi Brewnog. The clamping force is of course a direct function of the bolt load or tensile stress in the bolt. Force is stress times area, so for any given bolt area, the higher the stress, the higher the force.
As for how much it stretches, that's only dependent on the modulus of elasticity. The stretch of a bolt is per Hook's law - strain times the modulus equals stress. A grade B16 bolt will have the same modulus as the higher strength bolt, so you'll actually get more strain (stretch) from the higher strength one because you can increase the tensile stress of the stronger bolt.
The conclusion then is that the stronger bolt will stretch more and end up with a higher clamping load.
Hi Fred. I know from experience that B16 is a common bolting material for piping systems. In all the piping codes (B31.1, B31.3, etc) there is a materials section giving you the allowable stresses which is an outstanding reference I might add. In the material section of the piping codes is a bolting material section which covers the various grades of bolts. ASTM A 193 has various grades in it including (from memory) B1, B5, B7, B8 and B16. Why they skip around like that I don't know. But the ASTM spec is what gives you the chemical composition and material properties. The piping codes only gives you stress allowables, yield and ultimate stress.
I have B31.3 sitting on my desk, but I don't use it enough to know it that well. I will have to look through the materials section. Thanks for the tip. Ya learn something new every day.
I looked at ASTM A193 and sure enough, there it is. I was hoping there was a way to cross reference the specs some how, but nothing comes up in our spec system. Oh well.
Ah, I was under the impression that the weaker bolt would also be less stiff, and therefore capable of pulling tighter on the threads at the end of the bolt. Thanks for that. The additional problem is that we're having trouble with the capscrews because of access, and are snapping Allen keys all over the place so wanted to try something with a hex head (and something which we wouldn't have to go out and buy!). We thought about durloks too, but figured that they would only help stop the bolts coming loose, rather than allowing more of a clamping force to be used.
Cheers.
Hi,
Does anyone know the torque capability of a 5/8 in. allen socket for a 3/4 in. socket head B18.3 capscrew. The comment about allens snapping off made me wonder if this is published information.
Thanks
You need to provide thread diameter and pitch, and tensile strength. I believe B18.3 only specifies dimensions.
Also, it makes a big difference what the coefficient of friction is, so it's dependent on materials and any lubrication as well.
3/4-10 ANSI B18.3 x 2-1/2 NON STD MATRL A-193 GR B7 105 ksi min Sy, 35 ksi Sm
7/8 in. hole
Assume torque range 268-387 ftlb
Assume 5/8 in. hex socket
Also assume non lubricated K=.2
One more thing, I have already looked at bearing stress, just was wondering about the allen socket itself after I heard they were "breaking" - just curious what torque caused them to break and what size allen socket was used?
Sounds like you're referring to a specific incident or incidents. I've heard of 'Chinese bolts' or other fasteners not being made to spec, but those stories aren't about a specific size bolt, they're very general in nature.
When you say "break" do you mean that the shank itself failed or the threads failed?
Q Goest
Brewnog said:
"The additional problem is that we're having trouble with the capscrews because of access, and are snapping Allen keys all over the place so wanted to try something with a hex head "
My concern is how are Allen keys rated so that you might know their torque capability prior to getting into what brewnog describes...
Allen keys aren't rated unfortunately. If you look at the size of the key compared to the size of the cap screw (for standard sized cap screws)*, you'll find the key has a dimension across the flats roughly equal to, or very slightly smaller than, the minor diameter of the thread. The key however, is generally of very high strength steel, even higher than a bolt, so in generally the key is strong enough to torque a cap screw right the way up to the point of breaking. At this point, depending on the strength of the cap screw, the Allen key may also be very close to breaking, so which one breaks will depend on material strength among other factors.
There are other factors however. The head of the screw creates friction with the parts being bolted such that the screw head can resist some torque without transfering that torque to the threaded portion of the cap screw.
In general, Allen keys should hold up to the torque requirements of the cap screw. Given the example provided, (a 3/4-10 UNC cap screw torqued to 387 ft lb) the shear stress in either part is unusually high. I could see either part shearing.
Before such bolts shear however, I've generally found the Allen key gets rounded off, or the cap screw socket deforms. If you're experiencing failed Allen keys or rounded off parts, it may be because the torque specified is too high.
*Note: Although standard sized cap screws should be ok, many of the low head cap screws have minor diameters much larger than the Allen key, such that the Allen key is much more likely to fail in shear. You may want to clarify if standard or low head cap screws are being used.
Q_Goest,
Thank you!
  • · Replies 38 ·
13K
  • · Replies 118 ·
13K
