Unwinding a string around a spool, what is the angular acceleration?
The angular acceleration of a solid cylindrical spool unwinding a string can be accurately calculated using the formula: angular acceleration = (mass * g * radius) / moment of inertia. Given a spool with a radius of 0.0195 m and mass of 0.380 kg, and a hanging mass of 8.40 kg, the moment of inertia is calculated as I = 1/2 * m * r^2, resulting in I = 3.5715e-5 kg*m^2. Substituting the values into the angular acceleration formula yields approximately 459.917 rad/s², correcting the initial erroneous calculation of 22241.14162 rad/s².
  • Understanding of Newton's second law of motion
  • Familiarity with moment of inertia calculations
  • Knowledge of angular motion concepts
  • Basic proficiency in algebra for rearranging equations
  • Study the derivation of moment of inertia for various shapes
  • Learn about rotational dynamics and torque
  • Explore the relationship between linear and angular acceleration
  • Practice solving problems involving pulleys and spools in physics
Physics students, mechanical engineers, and anyone interested in understanding rotational motion and dynamics in mechanical systems.
mustang
Problem 5. given:g=9.81m/s^2.
A light string 1.20 m long is wrapped around a solid cylindrical spool with a redius of 0.0195 m and a mass of 0.380 kg. A 8.40 kg mass is then attached to the free end of the string, causing the string to unwind from the spool.
a. What is the angular acceleration of the spool? Answer in rad/s^2.
Note : I worked on the problem and I got 22241.14162 by using the formula (moment of inertia* angular acceleration= mass*g*radius. However my answer was wrong what did I do wrong?
You are assuming that the tension in the string (which is what is pulling on the spool) equals the weight of the mass.
To do this problem correctly, treat each object separately. Consider the forces acting on each body, and write down the equations describing each. You'll have two equations and two unknowns. And the right answer.
Based on the given information, the angular acceleration of the spool can be calculated using the formula: moment of inertia * angular acceleration = mass * g * radius. In this case, the moment of inertia can be calculated as I = 1/2 * m * r^2, where m is the mass of the spool and r is the radius. Substituting the given values, we get I = 1/2 * 0.380 kg * (0.0195 m)^2 = 3.5715e-5 kg*m^2.
Next, we can rearrange the formula to solve for angular acceleration: angular acceleration = (mass * g * radius) / moment of inertia. Substituting the given values, we get angular acceleration = (8.40 kg * 9.81 m/s^2 * 0.0195 m) / 3.5715e-5 kg*m^2 = 459.917 rad/s^2.
Therefore, the angular acceleration of the spool is approximately 459.917 rad/s^2. It is possible that your answer of 22241.14162 was incorrect because you may have used the incorrect value for the moment of inertia or made a calculation error. Double-checking your calculations can help identify any mistakes.
  • · Replies 17 ·
  • · Replies 33 ·
