Solve Calculation: Mass of Ice Melted with Carrots at 100°C
  • Thread starter Thread starter fabbo
    Confused
The discussion revolves around calculating the mass of ice melted when 825g of carrots, heated to 100°C, are placed in an ice-water mixture. The specific heat capacity of the carrots is 3700 J/kg/K, and the specific latent heat of fusion of water is 330 kJ/kg. The initial temperature of the carrots is confirmed to be 100°C, and since some ice remains after thermal equilibrium, the final temperature of the carrots must be above 0°C but below 100°C. This understanding is crucial for accurately determining the energy transfer and subsequent mass of ice melted.
  • Understanding of specific heat capacity and its calculation
  • Knowledge of latent heat of fusion and its application
  • Basic principles of thermal equilibrium
  • Ability to perform energy balance calculations
  • Calculate energy transfer using the specific heat capacity formula
  • Explore the concept of thermal equilibrium in heat transfer problems
  • Study the calculations involved in latent heat of fusion
  • Practice similar problems involving heat transfer between solids and liquids
Students studying thermodynamics, physics educators, and anyone interested in heat transfer calculations in practical scenarios.
fabbo
Ok, I had these questions for homework and had no problems with them except this one.
A variety of carrots has a specific heat capacity of 3700J/Kg/K. A saucepan of boiling water is used to raise the temperature of 825g of these carrots to 100 C. The carrots are then drained and immediately transferred to a large amount of ice and water in a plastic bowl. some of the ice still remains when the carrots achieve thermal equilibrium with the ice/water mixture. The specific latent heat of fusion of water is 330kJ/Kg. Calculate the mass of ice that melts during this process.
The only way I know how to work it out is by first calculating the energy put into the carrots using the specific heat capacity equation but we are not given a temperature rise. Should I assume the rise is 100 C. Any help is gratefully received. X
You are told that the carrots--just before they are transferred to the bowl of ice/water--were at a temperature of 100 C. That's the initial temperature of the carrots. Since some ice remains after equilibrium is reached, what must be the final temperature of the carrots?
oh i get it now - thank you!
  • · Replies 17 ·
