| Thread Closed |
Finding the kernel and range of a tranformation |
Share Thread | Thread Tools |
| Dec1-05, 10:17 AM | #1 |
If L(x) = (x1, x2, 0)^t and L(x) = (x1, x1, x1)^t
What is the kernel and range? |
| Dec1-05, 06:16 PM | #2 |
Do you know the DEFINITION of "kernel" |
| Dec1-05, 07:15 PM | #3 |
I need to do both. I know the kernel is basically setting to zero, but my book is awful on explaining stuff. I also know the range is basically solving for y and row reducing, but I am foggy on the presentation.
| Dec1-05, 09:11 PM | #4 |
I'll explain it to you, and I want to see you attempt to answer it.
The range is simple. It's just like Calculus, sort of. For example, the function f(x)=x^2 has a domain of R(-infinite,infinite), and range (0,infinite). The range is simply all the possible vectors you can obtain from the transformation. If T(x) = (0,0), then all the possible vectors that come "out" of the transformation are in the set {(0,0)}, which is the range. What's the range of T(x)=(x,y)? The answer is R^2, which is any vector in the Cartesian Plane. The kernel of a transformation is the set of vectors that transform into the zero vector. So, for the first one T(x)=(0,0) is all the vectors, since all the them become a zero vector, so the answer is R^2. What's the kernel of T(x)=(x,y)? Well, the only possible vector that can transform into a zero vector is the zero vector itself. Note: I have no idea what you mean by exponent t. Maybe that signifies that it is a transformation... I have no idea. |
| Dec2-05, 06:20 AM | #5 |
For your first function L(x1,x2,x3))= (x1, x2,0). Set that equal to 0: (x1, x2,0)= (0, 0, 0). What does that tell you about x1 and x2? What does it tell you about x3? Now the range: what do all possible values of L, that is all vectors of the form (x1, x2,0), have in common? |
| Dec2-05, 06:56 AM | #6 |
Mentor
Regards, George |
| Dec2-05, 09:04 AM | #7 |
| Dec2-05, 09:51 AM | #8 |
Then I'm surprised that you don't know that AT is a standard notation for transpose.
| Dec2-05, 12:22 PM | #9 |
| Dec2-05, 01:01 PM | #10 |
Recognitions:
You can't guess that lower and upper case t in an expression x^t or x^T where x is a vector don't both obviously mean transpose?
| Dec2-05, 03:23 PM | #11 |
Anyways, the question isn't about transposes. |
| Dec2-05, 03:29 PM | #12 |
Recognitions:
It's about vectors, and linear maps. What on Earth was it going to be except transpose?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Finding the kernel and range of a tranformation
| Finding range and kernel of linear transformation | Calculus & Beyond Homework | 3 | ||
| Need help finding a derivation of the range formula | General Physics | 1 | ||
| finding a basis of a Kernel | Calculus & Beyond Homework | 13 | ||
| Finding time and range for a projectile launched from a cliff | Introductory Physics Homework | 1 | ||
| Kernel and range | Introductory Physics Homework | 4 | ||
