| Thread Closed |
fluid pressure difference |
Share Thread | Thread Tools |
| Dec1-05, 03:31 PM | #1 |
A patient is given an injection with a hypodermic needle 3.2 cm long and 0.25 mm in diameter. Assuming the solution being injected has the same density and viscosity as water at 20°C, find the pressure difference needed to inject the solution at the rate of 1.5 g/s.
ok I have the equation V = [(P1-P2)(pi*r^4)]/(8*n*L) (P1-P2)= pressure difference r= .000125 m n= .0010055 L= .032 m I do not know how I am suppose to transform 1.5g/s to m/s because im unsure of how to transfer grams to meters.... once i get that I can find the difference in pressure... In a similar problem with diameter being .28mm the answer came out to be 320kPa... help??? |
| Dec1-05, 07:53 PM | #2 |
Recognitions:
Pressure energy is converted into kinetic energy.
To convert volume flow into velocity, you can consider: [tex]\dot{V}= A\cdot v[/tex] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: fluid pressure difference
| Pressure of Fluid | Mechanical Engineering | 19 | ||
| Conceptual Pressure Question: Fluid Pressure in a U-Tube | Introductory Physics Homework | 1 | ||
| fluid pressure | Introductory Physics Homework | 3 | ||
| Fluid Pressure and Fluid Force in Calculus II | Introductory Physics Homework | 12 | ||
| Fluid Pressure | Introductory Physics Homework | 4 | ||
