The Feeling of Cold: Where Does It Come From?
  • Thread starter Thread starter blt93932
    Cold
The discussion centers on the origins and mechanisms behind the sensation of cold, exploring both physiological and physical perspectives. Participants examine how temperature differences affect human perception and the biological processes involved in sensing temperature changes.
  • Some participants propose that the feeling of cold arises from heat leaving the body at a rate that is uncomfortable, particularly in colder environments.
  • One participant explains that touching an ice cube feels cold because it draws heat away from the hand until thermal equilibrium is reached.
  • Another participant mentions that an endothermic reaction relates to the sensation of heat leaving the body.
  • It is noted that the body must exert more effort to maintain internal temperature in colder conditions, which may heighten sensitivity to temperature differences.
  • One participant suggests that the sense of temperature could be considered a fundamental human sense, akin to sight or taste.
  • Another contribution highlights the role of specific nerve fibers in transmitting sensations of heat and cold.
  • A participant recalls a connection between temperature perception and the coagulation of proteins affecting nerve firing.
  • Information from a wiki entry indicates that thermoception involves different types of sensors for detecting heat and cold, and that the mechanisms are still under investigation.
Participants express various viewpoints on the mechanisms of cold sensation, with no clear consensus on a singular explanation. Multiple competing ideas and hypotheses remain present in the discussion.
The discussion reflects ongoing uncertainty regarding the biological and physical processes involved in temperature perception, as well as the definitions and mechanisms of thermoception.
blt93932
Where does the feeling of cold come from? Is it from heat rushing past cells, when we step outside in the cold, that creates this feeling we signal as cold?
Biology news on Phys.org
Coldness is the absense of heat and the difference between your body heat and the temperature around your body. The sensation comes from the feeling of heat leaving our body at a faster than comfortable rate. This can be an isolated or global feeling. So if you touch an ice cube it feels cold because the ice cube is drawing heat away from your hand and into the ice cube until it melts and creates an equilibrium between the temp of your hand and the ice cube. This is a laymans explanation.
An endothermic reaction. So I was sort of correct with my explanation, the feeling of heat rushing past the cells and leaving the body.
Your body has to work harder to maintain its constant internal temperature when the environmental temperature is lower, even when there is no wind to rush past. So your nerves have evolved to be sensitive to temperature differences.
When it's hot with a wind and you sweat, the sweat evaporates, and by basic physics that cools your skin, and the nerves there sense that.
I would like to suggest that a "sense of temperature" is in fact a fundamental human sense, such as sight, taste, smell, etc. I would welcome other thoughts on this.
You're right Rade,
The feeling of heat/cold doesn't exist without a system in our body.
They are speaking about physics but there is effectivelly a transition of the physical event (cold) to a neuron firing carried by Alpha D fibres in human. Warmth is carried by C fibres.
I remember something about coagulating proteins that cause certain nerves to fire??
The wiki offers help:
Thermoception is the sense by which an organism perceives temperature. In larger animals, most thermoception is done by the skin. The details of how temperature receptors work is still being investigated. Mammals have at least two types of sensor: those that detect heat (i.e. temperatures above body temperature) and those that detect cold (i.e. temperatures below body temperature).
  • · Replies 27 ·
  • · Replies 26 ·
20K
