Period of small oscillations in central potential
The discussion focuses on determining the period of small oscillations for a particle in a central potential defined by V(r) = -k(e^{-αr})/r. The effective potential is expressed as V_eff(r) = -k(e^{-αr})/r + (l²)/(2mr²), where l represents angular momentum. The minimum of the effective potential occurs at r_0, allowing for circular motion. The period of oscillations around this orbit is independent of the particle's energy or angular momentum.
  • Understanding of central potential and effective potential in classical mechanics
  • Familiarity with the concepts of angular momentum and centrifugal potential
  • Knowledge of oscillatory motion and its mathematical representation
  • Basic proficiency in calculus, particularly in solving differential equations
  • Research the derivation of the period of small oscillations in classical mechanics
  • Study the properties of effective potentials in central force problems
  • Explore the mathematical techniques for analyzing stability in dynamical systems
  • Learn about perturbation theory and its applications in oscillatory motion
This discussion is beneficial for physicists, particularly those specializing in classical mechanics, as well as students studying dynamics and oscillatory systems.
Chen
Hi,
A particle is subjected to a central potential of:
[tex]V(r) = -k\frac{e^{-\alpha r}}{r}[/tex]
Where [tex]k, \alpha[/tex] are known, positive constants.
If we make this problem one-dimensional, the effective potential of the particle is given by:
[tex]V_{eff}(r) = -k\frac{e^{-\alpha r}}{r} + \frac{l^2}{2 m r^2}[/tex]
Where the second term is the "centrifugal potential", [tex]l[/tex] is the absolute value of the angular momentum the particle has.
Now suppose that this effective potential has a minimum at [tex]r_0[/tex], which is known, so that if placed there the particle will have a circular motion.
The question is - what is the period of small oscillations (in the r-dimension) around the circular orbit?
The answer needn't depend on the energy of the particle or its angular momentum.
Thanks,
Chen
You know the rules: Post what you've got so far, and we'll help from there.
I've solved it myself. Thank you very very much.
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 25 ·
