Travel Instantly: Is Distance Still a Factor?
  • Context: Undergrad
  • Thread starter Thread starter Ulnarian
    Travel
The discussion centers around the concept of instantaneous travel between two points, specifically questioning the implications for distance when time is considered to be zero. Participants explore theoretical scenarios, the limitations imposed by current physical laws, and philosophical considerations regarding the nature of distance and movement.
  • Some participants question the definition of distance when considering instantaneous travel, suggesting that it could be whatever one defines it to be in a nonphysical context.
  • Others argue that according to current physical laws, particularly special relativity, nothing with mass can travel at or faster than the speed of light, making instantaneous travel impossible.
  • A few participants introduce the idea of massless objects and quantum phenomena, such as quantum tunneling, as potential exceptions to the rules governing speed and distance.
  • Some contributions highlight the philosophical implications of instantaneous travel, suggesting that it leads to paradoxes regarding the location of an object at time=0 and the nature of movement without time.
  • One participant emphasizes that the concept of instantaneous travel is flawed, as it implies being in two places at once, which challenges the conventional understanding of travel and distance.
  • Another participant discusses the experience of a photon, noting that from its perspective, distances are irrelevant because no time elapses during its travel.
  • Concerns are raised about the implications of defining travel when time is zero, suggesting that such a scenario does not constitute travel in the traditional sense.
Participants express a range of views, with no consensus reached on the nature of instantaneous travel or its implications for distance. Some agree on the limitations imposed by special relativity, while others propose alternative interpretations or challenge the assumptions underlying the discussion.
Limitations include unresolved definitions of distance in the context of instantaneous travel, the dependence on interpretations of physical laws, and the philosophical implications of time and movement.
Ulnarian
Please fogive any ignorance I may have of this subject, I am not a physicist :), I did however take a physics class in college.
In that class, I learned that distance=rate of travel/time taken to complete the journey.
One thing I've always wondered about that is, say that it is possible (somehow) for an object to move from point A to point B INSTANTANEOUSLY (Time=0), what than is the distance between points A and B?
no its impossible, nothing with mass can move at the speed of light (or faster than the speed of light).
Lets say it is possible :) (I dunno, maybe a massless object...)
wow. I've never heard that question before. Emm according to current physical laws, it is not possible to travel faster than the speed of light, so nothing can travel any non-zero distances instantaneously. (That's special relativity for you). Annoyingly Quantum mechanics tells us you can't be sure if something is stationary (Heisenberg is to blame for that with his uncertainty principle) and so if we limit ourselves to a physics discussion ermmm, oops... philosophically? mmm, well infinity can't even be discussed, and zero, well zero implies no dimension, and with no dimensions you can't measure distances, and so it seems that your question cannot be discussed neither in physics nor in philosophy. Why not apply the limits given by Einstein and the other clever people who applied them? =) hope i helped :P
I have earlier discussed the same thing. the fact that you might help me is how to show a link?
anyway what you said opposes mathematics. there cannot be discontinuity in the rate ofgrowth of something. i think the title to that post was something like discontinuities. though it is not same topic you will get your answer there.
in short the answer is there is nosuchthing as infinite velocity. may even the bodybe massless for this case. masslesspoint comes into pictue during acceleration. so the rate of travel can neverbe infinity.
As others have stated, it is an unphysical assumption to have something traveling faster than light, much less infinitely fast. But even if something did travel "instantaneously", I don't get your question. The distance between A and B could be whatever you want them to be. (In the nonphysical world of instantaneous travel, distance is irrelevant.)
If quantum tunnelling counts as 'instantaneous' (and I'm not sure that it does), then the distance is whatever the spatial displacement of the particle is. You'll just have to alter your definition of 'distance'. Otherwise you'd be dividing infinity by zero. :bugeye:
In my opinion... I'm not a physicist, but anyway. Time could never equal 0. Even if any speed is attainable. For example, when you walk into a room and turn on the light. The movement of the switch and the light particles/waves being emmitted from the filiment are not instantaneous even though it may seem so. In movement, which distance implies, there is always time passage.
Everyone who referenced Special Relativity is, of course, correct. No object with mass can reach the speed of light (definitely not infinity) and massless objects go only the speed of light ... again that is "only" 300,000 Km/sec. However, Bell's theorem and subsequent experiments indicate that there is some form of "instantaneous" interaction with the manifestations of a quanta. Not what ulnarian was looking for, probably.
The distance between points A and B is the same distance between points A and B as if you had never travelled. In other words, you DON'T need to measure the time in order to measure the distance between two points.
In this situation, you wouldn't be able to measure the rate (or velocity) of travel because it would be "instantaneous" (or the velocity would be infinitely fast) so the relationship d=vt would not be applicable. It would be as if someone "teleported" from one place to another ala Star Trek without any "movement" in between to observe.
This whole idea of anything happening "instantaneously" without a time factor is flawed. At time=0 where is the object, point A or B? It would have to be both places at once. Not to mention instantaneous in which reference frame? There is no movement without time.
Or both A and B would have to occupy the same space at the same time. Either way d=vt does not apply.
My knowledge of physics is limited, but I'd like to know how it is possible for an object to have no mass, isn't light made of particles that move in the form of a wave? Doesn't that mean that light particles travel at the speed of light?
That's just it. I just recently finished a book on Special Relativity that talked about this. I was reading a section about the life of a photon, in it's own point of view.
The distance between the Earth and the farthest point imaginable, to the photon, is zero. There is no difference, to the photon, between these two places, because NO time elapses for it to get there. The photon is created and destroyed all at the same time. It's a bizarre notion, but I suppose that's relativity for you!
The photons (quanta) of light do not possesses mass. It would be impossible for them TO possesses mass, if they wanted to travel at the speed of light. This is because, even if something has a tiny amount of mass, it will take an infinite amount of energy to accelerate a massive object to the speed of light. It just takes more and more energy, without limit, and so the speed of light will never be attained by something that possesses mass.
Just because photons are particles does not imply that they are massive (though the large majority of particles do have mass, including other carriers like W and Z bosons, which carry the electroweak force.)
Macca, there's a very nice thread just around the neighbourhood of this one that deals with the issue of light wave/particle duality (there isn't really such a thing). It will help alleviate your confusion regarding the matter.
If t = 0 then this can not be called a 'travel' IMHO. How do you define 'travel' or 'transportation'? And it also means to me that being at two observable places simultaneously. This is not travel also. But if you say that t->0 then v->\infty implies v > c ( speed of light ) Which is not physical atm.
Huh? :confused:
As seen in these replies, all are limited in their response by what they have been taught. The only limits in this universe are self imposed by ourselves. Once we throw out all commonality and narrow boxed thinking, all things become possible. EVERYTHING is a possibility if we only strive to believe it possible. Chilkdren are a perfect example. Why is it that very young children have the abiality to learn anything at all ? Our brains are infinite in what they can understand if we only stop saying something isn't possible and expect all things to BE possible and therefore never give up the search for the way to make it happen. Believe that everything is possible my friends and it WILL happen...we just haven't found the answers yet...
I should stress it's not possible to "accelerate" from point A to point B faster than light, but there is nothing saying that the probability of an object cannot correlate to a distance larger than it would take light to travel (i.e. entanglement, quantum mechanics).
If I'm not mistaken there are no laws governing how fast space itself can move. Especially considering that the universe itself expanded at FTL. Sooo 'in theory' if one knew how to manipulate the fabric of space it could be possible to travel almost 'instantaneous'.
Do you something better than SR? Sure, you can bring up the neutrino anomaly, but atm that's just what it is...an anomaly. a lot of stuff doesn't add up in that OPERA experiment: those neutrinoes being faster than ones in SN1987 yet having higher energy, also from the supernova the neutrinoes arrived when they should have, etc.
The only thing I know of at all being FTL is quantum entanglement.
If you could travel instantaneously, the rate of travel would be infinity and the time would be zero, so that meaaaaaaannssss...
sorry my TI-89 ran out of batteries :/
This thread is six years old.
Wow, I just realized that now that you said something. Lol dang klingon you revived this thing just to say that?
Exactly. Could everyone please check the dates of threads when posting and report crackpottery when they see it rather than responding.
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 65 ·
14K
  • · Replies 35 ·
  • · Replies 64 ·
  • · Replies 17 ·
