Can an electron escape a charged black hole after crossing its event horizon?
  • Context: Graduate
  • Thread starter Thread starter stanleykorn
    Black hole Hole
The discussion revolves around the theoretical possibility of an electron escaping a charged black hole after crossing its event horizon. It explores concepts from general relativity, electrostatics, and the behavior of particles in extreme gravitational fields, with a focus on thought experiments and hypothetical scenarios.
  • Some participants propose that if a black hole becomes sufficiently charged, the electrostatic repulsive force on an electron could exceed the gravitational force, allowing for a scenario where the electron crosses the event horizon and potentially escapes.
  • Others argue that the gravitational force will always dominate due to the mass of the electrons, suggesting that the initial premise may be flawed.
  • A participant highlights that general relativity does not treat gravity as a force in the same way as Newtonian physics, indicating that the assumptions made in the thought experiment may not hold in a relativistic context.
  • Some contributions emphasize the complexity of the situation, noting that a charged black hole would not remain stable and would likely radiate particles, complicating the scenario further.
  • One participant suggests using the geodesic equation modified for electrostatic forces to analyze the motion of charged particles near a black hole, indicating that the dynamics are more complex than initially presented.
  • Another participant mentions that while an observer cannot pass back through the event horizon of a black hole, under certain idealized conditions, it may be possible to enter and exit through different horizons in a charged black hole scenario.
Participants express multiple competing views regarding the behavior of electrons in the vicinity of a charged black hole, with no consensus reached on the possibility of escape after crossing the event horizon.
Limitations include the reliance on Newtonian gravity in a general relativity context, the assumptions about the stability of charged black holes, and the potential oversimplification of the dynamics involved in particle interactions near such black holes.
stanleykorn
Consider the following thought experiment. Electrons are propelled into an ordinary (nonrotating) black hole until the black hole has a sufficient electrostatic charge so that the electrostatic repulsive force on the next electron is greater than the gravitational attractive force. Since both the electrostatic force and gravity vary inversely with the square of the distance from the black hole, this next electron will experience a net inverse square repulsive force. Now suppose that this next electron is propelled towards the black hole with sufficient initial velocity so that it crosses the event horizon of the black hole. While an observer on this electron would observe the electron cross the event horizon in a finite amount of time, an infinite amount of time will have elapsed in the outside universe. Once inside the event horizon, the electron cannot fall into the singularity due to the net repulsive force, but must at some point be propelled away from the singularity until it recrosses the event horizon. Meanwhile, an infinite amount of time will have gone by in the outside universe into which the electron has re-entered, while the observer on the electron will have experienced the elapse of only a finite amount of time. Is that possible?
I'm not an expert, but don't your electrons have mass? as you pump more and more electrons into the black hole the the repulsive force may grow, but the gravitational force is also growing and will always be stronger. that's what makes it a black hole after all
In Newtonian gravity, gravitational force is proportional to the inverse square of the distance, but obviously you can't assume the same in general relativity, since if this was true in GR then you could always escape a black hole's pull by applying a sufficiently large force, and there'd be no such thing as an 'event horizon'. GR doesn't express gravity in terms of a 'force' at all, although I guess in the Newtonian limit you should be able to approximate it that way.
To be honest, this is a far more complicated problem than you probably realize. The first part of that starts with the fact that gravity is NOT a force in GR. You're using Newtonian gravity in a GR regime, which does not work, at all. Not even as an approximation. Its Ptolemy's sphere's to Kepler's orbits (ok, its not that bad, but the analogy to their relative usefulness is...well, useful).
That said, a particle cannot cross back over the event horizon, such a path is not allowed with a timelike (less that the speed of light) trajectory.
Also, such a black hole would not remain charged for long, it would radiate electrons via hawking radiation (essentially absorbing positive charge from quantum vacuum fluctuations, leaving electrons produced by the fluctuations free to escape. It is believed that a charged black hole will not exist "in the wild" because of this (although, that does not affect the question at hand).
Your model is already too simplistic. What you need to do to get an accurate analysis for the path of a charged particle is to use the geodesic equation, modified to include the electrostatic force
This is
[tex] m \left( \frac{d^2 r}{d \tau^2} + \Gamma^r{}_{tt} \left(\frac{dt}{d\tau}\right)^2 + \Gamma^r{}_{rr} \left(\frac{dr}{d\tau}\right)^2 \right) = e E_r[/tex]
I've omitted a number of terms which turn out to be zero from the general geodesic eq.
The charged BH is described by a Reissner-Nordstrom metric.
[tex]ds^2 = f(r) dt^2 - \frac{dr^2}{f(r)} - r^2 d\theta^2 - r^2 sin^2 \theta d\phi^2 \hspace{.25 in}f(r) = (1-\frac{2M}{r}+ \frac{Q^2}{r^2})[/tex]
This gives
[tex]\Gamma^r{}_{tt} = \frac{(r^2-2 M r+Q^2)(M r - Q^2)}{r^5}[/tex]
[tex]\Gamma^r{}_{rr} = -\frac{M r - Q^2}{r (r^2-2 M r+Q^2)}[/tex]
E_r does turn out to be Q/r^2
Howver, gravity is not of the simple form you propose - the static field is due to [itex]\Gamma^r{}_{tt}[/itex] via a much more complex expression than 1/r^2, and there is an additional quadratic term [itex]\Gamma^r{}_{rr}[/itex] that has no interpreation as a "force".
Alternatively to using the geodesic equations, one could use some of the conserved quantities for this metric - this is computationally more convenient, but doesn't give as much insight.
While your analysis above is much too simplistic, strange things do happen with charged black holes (much stranger than even those strange things that happen with uncharged black holes).
An observer can never pass back through the event horizon of a black hole, but under certain circumstances, such as the idealized geometry I gave above, it is possible for an observer to enter such a charged black hole through one event horizon, and leave it through a different event horizion to "another universe".
However, the above simple geometry, while valid outside the event horizon of a charged black hole, is probably NOT valid inside the event horizon of a black hole, so this is probably not realistic for an actual charged black hole.
The best paper I know about on the topic of what really happesn to someone falling through a charged BH of the sort likely to form in nature is
http://lanl.arxiv.org/abs/gr-qc/9902008
  • · Replies 46 ·
10K
  • · Replies 43 ·
  • · Replies 40 ·
  • · Replies 73 ·
  • · Replies 51 ·
  • · Replies 57 ·
  • · Replies 26 ·
  • · Replies 25 ·
