How Do You Calculate Torque in Mechanical Situations?
  • Thread starter Thread starter hshphyss
    Torque
This discussion focuses on calculating torque in mechanical situations, specifically involving a car and a bucket system. The torque exerted by the car around the back wheels can be calculated using the formula τ = rF sin(θ), where the radius (r) is the distance from the axis of rotation to the point of force application, and θ is the angle between the force and the radius. Additionally, the minimum force required to raise a bucket attached to a cylinder is determined without needing to compute the moment of inertia, as it assumes zero acceleration. Key insights include the importance of understanding the direction of forces and angles in torque calculations.
  • Understanding of torque calculations using τ = rF sin(θ)
  • Knowledge of basic mechanics, including forces and angles
  • Familiarity with concepts of mass and center of mass
  • Basic understanding of rotational motion and inertia
  • Study the principles of torque and its applications in mechanical systems
  • Learn about the relationship between force, mass, and acceleration in rotational dynamics
  • Explore the concept of moment of inertia for various shapes and its impact on torque
  • Investigate practical applications of torque calculations in automotive mechanics
Mechanical engineers, physics students, automotive technicians, and anyone interested in understanding torque calculations in practical scenarios.
hshphyss
1.) A mechanic jacks up a car to an angle of 8.0° to change the front tires. The car is 3.20 m long and has a mass of 1160 kg. Its center of mass is located 1.12 m from the front end. The rear wheels are 0.40 m from the back end. Calculate the torque exerted by the car around the back wheels.
--I'm not sure how to set this up. I know the equation for torque is t=fr sin(theta)
2.) A bucket filled with water has a mass of 71 kg and is attached to a rope that is wound around a 0.035 m radius cylinder. A crank with a turning radius of 0.15 m is attached to the end of the cylinder. What minimum force directed perpendicularly to the crank handle is required to raise the bucket?
--I think this is a moment of inertia problem... so for that shape it would be MR^2 but after you find that what would you plug that into?
Thank-you
1) "r" points from the axis of rotation (the back wheels) to the point where the Force is applied. The first Force that you need to consider is the Force applied TO the car BY THE EARTH (gravity), which is downward. The angle that you take the sin of (in "sin theta") is the angle from the "r" direction to the "F" direction (swept thru by your fingers as they more from "along r" to "along F". In your case, it is MORE than 90 degrees.
[the wording "torque applied BY the car around the back wheels" implies that
there is some OTHER object, besides the car, that this torque is applied TO. I can't think of any ... the car cannot apply a torque to itself!]
2) the MINIMUM Force needed to raise the bucket will have zero acceleration of the bucket, and zero angular acceleration of the drum.
So you do NOT need to compute the moment of rotational Inertia.
  • · Replies 21 ·
  • · Replies 25 ·
12K
