Why Does My Derivative of log base3 of (x^3 + 2x) Answer Differ From My Book?
The discussion revolves around the computation of the derivative of the logarithmic function with base 3 applied to the expression (x^3 + 2x). Participants are comparing their results with a textbook answer, which has led to questions about the application of differentiation rules.
  • The original poster attempts to compute the derivative but questions the discrepancy between their result and the textbook answer, specifically regarding the inclusion of the derivative of the inner function in the numerator. Other participants suggest the necessity of applying the chain rule and clarify the derivative of a logarithmic function.
Participants are actively discussing the application of the chain rule in differentiation. Some have provided guidance on the correct approach, while others are exploring different interpretations of the problem setup. There is no explicit consensus on the resolution of the discrepancy yet.
There is a mention of the original poster's confusion regarding the application of the chain rule and the structure of the logarithmic function, which may indicate a misunderstanding of the differentiation process involved.
ranger1716
Ok, I worked this derivative problem, but my book has a different answer than what I got. I'm not sure why.
I need to compute the derivative of log base3 of (x^3 + 2x)
I came out with:
1/((x^3 + 2x)ln3)
The book says that the answer is the same as mine except the numerator has a (3x^2 + 2) in it.
Why would you put the derivative of the x value of the log function in the numerator.
My book says that D log base a of x = 1/xlna
help?
The book is right. Don't forget the chain rule. It is true that
[tex]\frac{d\ln{x}}{dx}=\frac{1}{x}[/tex]
, but
[tex]\frac{d\ln{u}}{dx}=(\frac{1}{x})(\frac{du}{dx})[/tex]
Have you heard of the "chain rule"?
The derivative of log3{x^3 + 2x}[/sub] is
[tex]\frac{1}{x^2+2x}(3x^2+ 2}[/tex].
Your mistake was to proceed with the wrong inverse function
[tex]\log_{3} x^{3} + 2x[/tex]
[tex]x^{3} + 2x = 3^{y}[/tex]
From this point you had to isolate x then differentiate the function and put it to power -1, which is not efficient. Use the chain rule http://people.hofstra.edu/faculty/Stefan_Waner/RealWorld/proofs/chainruleproof.html"
  • · Replies 25 ·
