Thread Closed
Event Horizon
Share Thread Thread Tools
Dec4-05, 09:07 AM   #1
Event Horizon
hi,
i was just wondering as the mass of the blackhole keeps increasing due to increased mass getting deposited on it does its event horizon increase
because of this?
does the blackhole have infinite density?
-Benzun
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Dec4-05, 09:35 AM   #2
Certainly does. And the yes, the spacetime inside a black hole is said to have infinite curvature and matter squeezed into infinite density.
Dec4-05, 12:57 PM   #3
ek
The "core" of a black hole is infinitely small and infinitely dense. But it does have a relatively "fixed" mass, that is to say that the mass is not infinite one way or the other, such as the volume or density.
Dec24-05, 11:12 PM   #4
Event Horizon
if infinite density exists wont its gravitationl potential be also infinite. So its evvent horizon would cover the entire space time.
i could be wrong. i am just learning so please help me.
-benzun
Dec25-05, 01:12 AM   #5
Recognitions:
Gold Membership Gold Member
I still vote for the planck density as the upper limit.
Dec25-05, 02:02 PM   #6
Quote by benzun_1999
-benzun
No, its gravitational potential is not infinite. A black hole is no different to any other celestial object one encounters in space. If a black hole has a mass of 15 solar masses, then objects gravitate around the black hole in the same manner as if they were orbiting a 15 solar mass star.
The second part about its event horizon, is all to do with escape velocity. Earth has an escape velocity of 11 kilometers a second, a black hole has an escape velocity of 300,000 kilometers a second which is also the speed of light, hence light cannot escape. Everything has an event horizon if it is compressed small enough, even the Earth has one if we were to shrink it into about the size of an atom.
Correction, the Earth would have a Schwarzschild radius of half a centimeter. (That’s the distance from the singularity in the center to its event horizon)
Dec27-05, 04:58 AM   #7
so i believe i am correct in telling that infinite density is not possible. there is a maximum density for anything in spacetime. i am kind of working on a theory like this. i dont know how to procced i will be really happy if anyone helps me. if interested pls pm me.
Dec27-05, 07:01 AM   #8
Well until we have a theory of quantum gravity, we aren’t really sure what happens inside a black hole, especially at the singularity. There’s nothing (AFAIK) in relativity to say infinite density is impossible. So if the planck conditions are reached inside a black hole, it will be limited by quantum gravity to about 10^94 grams per cubic centimeter.
Dec27-05, 07:46 AM   #9
Recognitions:
If the idea of infinite density, or alternatively a finite mass body collapsing down to a singularity of zero volume, seems impossible and unphysical, then ask: "What is it that prevents ordinary objects from not having zero volume? What gives objects in the physical world its geometrical structure?"
The answer is of course the strong nuclear and electro-weak forces. What happens then when the gravitational force inside an event horizon overcomes all other possible forces? What is it that prevents such a collapsing object from not collapsing to zero volume and infinite density?
Other forces stronger still will be required, so far we do not have the physics to deliver such strong replusive forces, yet.
Garth
Dec29-05, 12:46 AM   #10
Recognitions:
I would vote for the uncertainty principle. It insists all entities occupy a finite, albeit incredibly tiny volume - which works out to be the planck density.
Thread Closed
Thread Tools
Similar Threads for: Event Horizon
Thread Forum Replies
The Event Horizon and Dirac's Sea Cosmology 0
Event Horizon Special & General Relativity 1
Is only GR enough for proved the event horizon Special & General Relativity 4
Event horizon and singularity Special & General Relativity 2
Event Horizon = Singularity? Special & General Relativity 1
