How to Apply Heat Flow Equations to a Sphere?
The discussion focuses on applying heat flow equations to a spherical geometry, specifically using the equation Q = -KA dT/dx for a spherical heat source. The user seeks guidance on determining the temperature at the surface of a heat-emitting sphere, given a constant temperature T_0 at the outer surface of a larger sphere. The solution involves using the equation \dot{Q} = KA(dT/dr) and integrating with respect to the spherical coordinates, taking into account the area of conduction A = 4πr². This method allows for the derivation of temperature profiles in spherical systems.
  • Understanding of heat transfer principles, specifically Fourier's law of heat conduction.
  • Familiarity with differential equations and integration techniques.
  • Knowledge of spherical coordinates and their application in physical problems.
  • Basic concepts of thermal conductivity and its role in heat flow.
  • Study the derivation of heat conduction equations in spherical coordinates.
  • Learn about steady-state heat transfer and equilibrium conditions in thermal systems.
  • Explore numerical methods for solving differential equations related to heat flow.
  • Investigate applications of heat transfer in engineering, particularly in thermal management systems.
Students and professionals in physics and engineering, particularly those focused on thermal dynamics, heat transfer analysis, and materials science.
capslock
I have derived expression for the heat flow along a bar with cross-sectional area A, given by 'Q = -KA dT/dx' where K is thermal conductivity constant and T and x refer to temperature and distance measured from the high temperature end of the bar.
I understand this. My problem is when I try to apply it to a sphere:
Say we have a spherical heat source of radius a at the centre of a solid sphere of radius b > a. Take the sphere as having thermal conductivity constant K. The source emits heat equally in all directions at a rate of Q per second. The outside of the outer sphere is help at constant temperature T_0.
How would I determine the temperature at the surface of the heat emitting sphere using the original differential equation?
I'm totally pulling my hair out about this one guys! Any guidance would be greatly appreciated.
Best Regards, James.
Stick to first principles, which is the equation you have started with:
Assume equilibrium conditions.
[tex]\dot{Q} = KA\frac{dT}{dr}[/tex]
where dT/dr is the temperature gradient at any distance r. The area of conduction at any distance r is [tex]A = 4\pi r^2[/tex].
Separate your variables and integrate accordingly. In case you didn't know, this same procedure can be used to derive your more familiar equation:
[tex]\dot{Q} = KA\frac{T_2-T_1}{x_2-x_1}[/tex]
Don't forget that heat flows from hotter to colder! :)
