How Does Temperature Affect the Resonant Frequency of a Hydrometer?
The discussion focuses on calculating the fractional change in the resonant frequency of a glass hydrometer when the temperature changes from 20 to 30 degrees Celsius. The resonant frequency is defined by the formula f = (1/2π) (Apg/m)^(1/2), where A is the area of the neck, p is the density of water, g is the acceleration due to gravity, and m is the mass of the hydrometer. Participants emphasize the importance of understanding the coefficients of linear and volume expansion for glass and water to derive the necessary relationships for solving the problem.
  • Understanding of resonant frequency in oscillatory systems
  • Familiarity with the coefficients of linear and volume expansion
  • Basic calculus, particularly differentiation and integration
  • Knowledge of fluid density and its relationship with mass and volume
  • Study the principles of resonant frequency in fluid dynamics
  • Learn about the coefficients of linear and volume expansion for different materials
  • Explore calculus techniques for solving separable differential equations
  • Investigate the relationship between temperature changes and fluid density
Students and professionals in physics, engineering, and materials science who are interested in fluid dynamics, thermodynamics, and the behavior of hydrometers under varying temperature conditions.
capslock
A glass hydrometer of mass m floats in water of density p. The area of the neck of the hydrometer is A. The resonant frequancy for the vertical oscillations of the hydrometer is given by
f = (1/2\pi) (Apg/m)^(1/2)
Calculuate the fractional change in the resonant frequancy when the temprature changes from 20 to 30 degrees C.
My effort:
(2f\pi)^2 = Apg/m
2ln(2f\pi) = ln(Apg/m)
2ln(2) + 2ln(\pi) + 2ln(f) = ln(A) + ln(P) + ln(g) - ln(m)
I tried to then differentiate but I got in a total kefuffel.
In the question it gives the 'coefficient of linear expansion' for glass and the 'coefficient of volume expansion for water.
Thanks in advance for any kind help you can offer. Best Regards, James.
First off, I'm not familiar with hydrometers, but as for rates of change, the question is asking you to find something of the form
[tex]\frac{df}{dT} = g(f, T)[/tex]
and of course hope that the equation turns out to be separable and thus easily solvable by integration over the range you need (i.e. T=20, T=30).
The information given to you, change in volume over time and change in length over time are: dV/dT and dx/dT.
These two variables V, and x are not in the original equation. You need to successively find relationships, for example:
[tex]\rho = \frac{m}{V}[/tex]
[tex]\frac{d\rho}{dT} = -\frac{m}{V^2}\frac{dV}{dT}[/tex]
Once you have the right relationships you can plug in.
9K
  • · Replies 17 ·
10K
11K
