How Do You Build a Crumple Zone for an Egg Drop with Toothpicks?
  • Thread starter Thread starter Frank_Horrigan
    Building
The discussion revolves around designing a crumple zone for an egg drop device using toothpicks and glue, with specific constraints on mass and height of the drop. Participants explore various structural ideas and concepts related to energy absorption and impact distribution.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants suggest different structural designs, including square and triangular bases, and consider the implications of using fewer toothpicks for connections. There is discussion about the role of vertical and slanted toothpicks in energy absorption and the potential for rotational motion. Some participants express uncertainty about the effectiveness of certain designs and seek clarification on concepts.
The discussion is active, with participants sharing ideas and feedback on various structural approaches. Some guidance has been offered regarding the importance of joint construction and the challenges of building complex designs like the octet truss. Multiple interpretations of how to achieve an effective crumple zone are being explored.
Participants are constrained by the requirement to use only toothpicks and glue, and the device must weigh 50 g or less. There are also concerns about the structural integrity and ease of construction of proposed designs.
Frank_Horrigan
For a school project I have to build a device made of only toothpicks and glue gun glue that will hold an egg. The device will be dropped 5 meters and the egg must not break, so the idea is to build a device with a good crumple zone. I have a few ideas about how to build it but its pretty hard to find advice on how they are made, I can only find info on how they work. Oh yea it has to have a mass of 50 g or less, that's a lot of toothpicks.
If someone could comment on my ideas, or suggest different variations it would be great. Here are my ideas.
1. Build a crumple zone where the base is made of squares each connected to a square above them by 4 toothpicks.
2. Same idea as above but use only 2 toothpicks to connect squares (therefore its weaker, which means I can have a longer crumple zone right?)
3. Make the base triangles that are connected to above triangles with 2 toothpicks.
4. Attempt to make it a shape sort of like a blimp? I have my doubts on this one.
Anyone have any ideas?
I expect that if the toothpicks are vertical they will not flex or break;
the Energy absorbed will only be in the glue coming undone.
It might be good to connect vertical toothpick posts
to the center of horizontal toothpick beams, so the beams will break.
If the posts are not vertical, but all slanted one direction,
you might be able to change vertical motion into rotational motion.
Hmm well with the vertical thing I've tried it a few times and it seems that the sticks do break. I don't really understand what you mean about rotational motion though, if you think it will help for my project please explain.
I was thinking that I need the structure to be very long and have the impact part break very easily over a long distance right? In this I am trying to create the longest stopping distance with equal force at all moments on the egg I think. So the best way to do this would b to have it reasonably weak but for as long of a time possible. Anyone have ideas how i would do this? or what shape would be the best to use that will break easily?
I rather like Buckminister Fuller's "Octet truss" consisting of tetrahedrons and octahedrons. You should be able to find diagrams if you look on the WWW. I have never actually seen this applied to egg drops, I don't have any emperical data on how well it works.
Some more feedback, after a little bit of fooling around with real toothpicks. The octet truss will probably theoretically be a very strong design, but it will be very hard to build correctly because of the joints.
If you put the joints of your toothpicks together haphazardly, the structure will not be very strong, defeating the purpose of the structure. You have to imagine that you are building on a larger scale, and use good joints.
The joint structre for a octet truss design can have up to 12 beams (toothpicks) meeting at a point, making it a difficult build. I think the best practical approach will be to engineer the structure for the simplest possible joint configuration.
15K
  • · Replies 18 ·
461K
