Static Equilibrium of massless rope
The problem involves a uniform sphere held in place by a massless rope attached to a frictionless wall, focusing on static equilibrium. Participants are exploring how to determine the tension in the rope and the force exerted on the sphere by the wall.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the necessity of a free body diagram (FBD) and the conditions for static equilibrium, including the balance of vertical and horizontal forces. There is exploration of the relationship between the tension in the rope and the geometry of the setup, particularly as it relates to the angle of the rope and the dimensions of the sphere.
Some participants have provided insights into the relationships between the forces and the geometry of the problem. There is an ongoing exploration of how to express the tension in terms of the given variables, with various interpretations of the triangle formed by the rope and the wall being discussed.
Participants note the lack of specific angles provided in the problem, which complicates the determination of the tension. The discussion also references a solution from a textbook, indicating differing approaches to the problem.
suspenc3
A uniform sphere of mass m and radius r is held in place by a massless rope attached to a frictionless wall a distance L above the Centre of the sphere. Find the tension in the rope and the force on the sphere from the wall.
I tried to get a picture, but it is apparently too big to host.
Do I start with a FBD? If so what should it look like?, How can I find T?
Is this what it looks like ?
Since the sphere is in static equilibrium, then all three forces must pass through the COM of the sphere.
Also, since the sphere is in static equilibriulm then the sum of the vertical forces is zero and the sum of the horizontal forces is zero.
ΣFV = 0
ΣFH = 0
http://img425.imageshack.us/img425/3193/suspenc4ie.th.jpg
Well the way to look at this is that the rope is fixed to the surface of the sphere, and one would have to draw a diagram with the rope at some angle to the wall.
The rope has length Lr, which is related to the height L and radius r.
For L >> r, the tension would simply be given by mg, the weight of the sphere, but as L -> r the tension becomes a function of the angle between the wall and the rope.
Yes..Thats what it looks like..
How can I find the tension...There are no angles given...
The answer in the back of the book says (mg/L)root(L^2 + r^2)
Draw a triangle and think about what L/root(L^2 + r^2) is, i.e. is one has a triangle of legs r and L, and hypotenuse sqrt(L^2 + r^2), how does one express the sin and cos of the angles?
so, [tex]sin \theta = \frac{L}{T}[/tex] where [tex]T = root(L^2 + r^2)[/tex]
Where does [tex]\frac{L}{mg}[/tex] come into place?
The tension T in the rope can be resolved into vertical and horizontal components. The vertical component of the tension must be equal to mg, the weight of the ball.
Therefore T cos [itex]\theta[/itex] = mg, where [itex]\theta[/itex] = [itex]\frac{L}{\sqrt{L^2+r^2}}[/itex], so
T = mg/cos [itex]\theta[/itex] = [itex]\frac{mg\sqrt{L^2+r^2}}{L}[/itex].
Then the horizontal force is simply equal to T sin [itex]\theta[/itex] and provides the force on the wall. I leave it to the student to finish.
  • · Replies 39 ·
  • · Replies 22 ·
  • · Replies 16 ·
