What Is the Final Temperature of a Heated Copper Ball?
  • Thread starter Thread starter FishieKissie06
    Ball Copper Final
The final temperature of a heated copper ball can be accurately determined using the volume expansion formula rather than linear expansion. The discussion highlights that for a copper ball with a radius of 1.4 cm and a diameter increase of 0.22 mm, the correct approach involves the equation (delta)V = 3*alpha*V*(delta)T. It is crucial to convert measurements to meters and use the radius for calculations to find the change in volume (delta)V accurately.
  • Understanding of thermal expansion concepts, specifically volume expansion.
  • Familiarity with the coefficient of linear expansion for materials, particularly copper.
  • Basic knowledge of geometry, specifically the relationship between radius and diameter.
  • Ability to perform unit conversions, particularly from centimeters to meters.
  • Study the principles of thermal expansion in solids, focusing on volume expansion equations.
  • Research the coefficient of linear expansion for various materials, including copper.
  • Practice converting measurements between different units, especially in thermal physics contexts.
  • Explore real-world applications of thermal expansion in engineering and material science.
Students in physics or engineering, educators teaching thermal dynamics, and professionals involved in material science or mechanical engineering will benefit from this discussion.
FishieKissie06
A copper ball with a radius of 1.4cm is heated until its diameter has increased by 0.22mm. Assuming a room temperature of 22*C, find the final temperature of the ball.
well what i did was i used linear expansion for this and i didnt get it right. i used (delta)L=(alpha)initial L*(delta)Temperature...solving for temperature
Well in order to do this... you must use volume expansion since it is not a rod gaining length... so you must use the equation... (delta)V = 3*alpha*V*(delta)T and for (delta)V you can substitute in V1-V2
and remember that you must have it in raidus and not diameter when finding (delta)V so... since the radius then increases by (d/2) you have to remember to convert to meters for both of the radius...
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 16 ·
