Differentiate y = x^x^x^x^...^x - Clues for Substitution
  • Thread starter Thread starter Reshma
The discussion revolves around differentiating the function y = x^x^x^x...^x, which is identified as an infinite power tower function. Participants are exploring appropriate substitutions and methods for differentiation.
  • Participants discuss the interpretation of the function as a hyperpower function and suggest reexpressing it in terms of itself. There are mentions of using natural logarithms and implicit differentiation, as well as considering the function as a power tower with potentially finite levels.
Some guidance has been offered regarding the use of logarithmic differentiation and implicit differentiation techniques. Multiple interpretations of the function are being explored, particularly concerning its infinite nature and potential substitutions.
There is an assumption that the function can be treated as a hyperpower function, and participants are considering the implications of this on the differentiation process. The nature of the infinite power tower raises questions about convergence and definition.
Reshma
Differentiate this?
I need some help to differentiate this function:
y = x^x^x^x^...^x
I am sure there's got to be some appropriate substitution for the x^ term. Any clues?
y = x^x^x^x^...^x
I'm assuming you meant the hyperpower function, which is the infinite power tower function. The x's go "all the way up".
You should read that function as [tex]y = x^{x^{x^{x^...}}}[/tex], that is, evaluate from the top down.
Then you can reexpress that as [tex]y = x^y[/tex]
Take natural logs of both sides and differentiate implicitly.
[tex]\ln{y} = y\ln{x}[/tex]
[tex]\frac{y'}{y} = \frac{y}{x} + y'\ln{x}[/tex]
Group the terms together.
[tex]y'(\frac{1}{y} - \ln{x}) = \frac{y}{x}[/tex]
And you can carry out further simplification yourself.
The given function is a so-called power tower.
It looks that the given function had finitely many levels, though.
You might try defining
[tex]f:y\rightarrow y^{x}[/tex],
and use f of f of ... of f and chain rule.
Thanks Curious4131 and benorin!
