Thread Closed
Thought Experiment
Share Thread Thread Tools
Dec7-05, 07:20 PM   #1
Thought Experiment
I have come accross this question in another forum and thought to post it here, hopefully will get some interesting views.
This is a thought experiment so the setting might not be achivable with todays technology and knowledge, instead try to look at the implications of this set up rather then the possibility of achiving such set up.
Imagine if we have a enclosed vacuum space, nothing can go in or out. We keep adding photons inside the enclosed space. (assume that whatever material or field we are using to enclose it will not absorb the photons, as well as the material used to generate the photons will not absorbe them). What would happen if we keep adding photons? What would happen if we increase the density of the photons in an enclosed vacuum space? Would they interact with each other? would they form some other form of particle that can carry more energy? What would happen?
Thanks to all in advance.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Dec7-05, 07:25 PM   #2
Recognitions:
Homework Helper Homework Help
If nothing can go in or out then how would you add photons?
Dec7-05, 07:33 PM   #3
I think the closest I can come to answering your question is this:
If you have a space completely enclosed by perfect mirrors (only reflect light, no absorbtion), no the photons won't interact. Assuming we are looking at this purely from the particle portion of the duality, the photons will just sort of bounce around forever.
Dec7-05, 09:19 PM   #4
Thought Experiment
Again do not look at how can we achive to do this experiment. I know that this is not possible to achieve today. I am more interested in the implication of this thought experiment.
TIDE: Assume the photon source is inside of the enclosed space.
KingNothing: Would they bounce forever if the density of photons would be very high and keep increasing?
Dec7-05, 10:30 PM   #5
Yes. They do not take up any space, hence why they are called "point particles". As such, density does not impose any limits on them.
Dec7-05, 10:56 PM   #6
True that density does not impose any limits, but because of large number of photons there might be some interference between each other.
Since photon is defined as wave and particle and in both concepts interference is a possibility that might as well happen in this case. But if so what kind of interference we might expect? What changes can we expect?
Dec8-05, 12:05 AM   #7
Recognitions:
Gold Membership Gold Member
This is a 'had an awful lot of beers, off the top of my head' response. I would think that eventually the photonic pressure would become large enough to rupture the enclosure.
Dec8-05, 04:01 PM   #8
Anyone else? I thought that this might spur some wild responses and speculations. Thanks
Dec8-05, 04:20 PM   #9
it would matter, if the photons are particles or waves, it particle you could fill the box , but if there wave you can never fill the box,
Dec8-05, 05:13 PM   #10
Mentor
Quote by marcppt
Think again. I have a standing wave cavity that I fill every day. The RF that I send in there has a filling time, etc. with very little, if any, leaking out.
Zz.
Dec8-05, 05:48 PM   #11
when you say fill time, are you talking about the time it takes to excite the electrons? or are you saying that you are filling it with photons.
Dec8-05, 06:23 PM   #12
Mentor
Quote by marcppt
You do know what "RF" is, don't you? How do you think particle accelerators work? They accelerate electrons using EM field (i.e. photons) using such cavities. You design such cavities so that it can sustain the mode of the RF frequency that you are using.
Zz.
Dec8-05, 07:11 PM   #13
Recognitions:
Retired Staff Staff Emeritus
One thing that's worthy of note. There is a critical field strength (volts/meter) at which one will start to create particles out of the vacuum, known as the Schwinger critical field.
So if one set up an RF cavity (or any other method of putting photons in a box) and got the required volts/meter (about 10^18) - (I think) theoretically one would start to create electron-positron pairs.
Google hasn't found much elementary discussion of the Schwinger critical field, one paper that talks about it a bit is
http://www.hep.princeton.edu/~mcdonald/e144/qedprop.pdf
Getting to 10^18 volt meter is left as an exercise for the student - actually I've seen papers arguing that we might be able to do this with lasers. IMO a box just complicates the problem with phenomenon such as field-aided emission, where the field (even below the Schwinger limit) would start tear electrons out of the conductors of the box via quantum tunnelling (assuming a resonant cavity to conatin the photons, which requires conducting walls).
The only reason to use a box is that's what the original poster asked about.
Issues of breakdown of boxes with high electrical fields brings up the interesting semi-related question of just how much voltage a vacuum capacitor can have without breaking down.
Eventually I'd expect electrons to be torn from the plates via field-aided emission, and the high energy electrons hitting the plates would knock lose other electrons, causing avalanche breakdown, even in a perfect vacuum.
I haven't seen anything numerical about this, though (i.e. limits on field strength in a vacuum capacitor). High work-functions for the electrodes would help in minimizing field-aided emission, and of course you need very smooth plates to keep the field strength down (points generate very high fields).
Dec8-05, 07:30 PM   #14
Mentor
There are problems with this, pervect.
1. Copper cavities, which are the most common material used, consistently break down at around 35 MV/m. It is why I get employed in my present field of study - people want a better acceleration mechanism rather than using copper LINAC. :) The superconducting cavity of Cornell/DESY made of Nb and Nb alloy are steadily getting to that level. So unless we make major technical progress, I don't think we'll be getting to the gradient you mention anytime soon.
2. Field emission is quite well-known in such cavities - they are the source of dark currents that we detect all the time.
3. Breakdown or arcing, on the other hand, is still a highly debated issue. The "consensus" so far is that while it can be initiated via field emission, this isn't the sole mechanism for breakdown. And even when it is initiated by field emission, it isn't what one typically thinks. What happens is that protrusions, having a higher field enhancement factor, will become extremely good field emitters. However, due to such small area of these emitters, there is a very powerful resistive heating going on even when the current is small. This leads to the melting of the material and POOF! There's the breakdown.
Zz.
Dec8-05, 07:37 PM   #15
The description of the photons as wave or particle is of little interest in this experiment. You can use one or the other or both to sustain an argument. The important questions raised; is there a critical point where:
1. No longer can add photons (able to fill the box).
2. Photons change properties as we know them and take some other form of energy carrier due to interaction between them.
3. Explosion!!
4. Observe previously unknown phenomena!!!
5. Other speculations!!!!
PS: Do not concern yourselfs with the how to set up such experiment, or whether it is posible, it is not part of the question raised.
Thanks again
Dec8-05, 07:52 PM   #16
Quote by leka
I would think they won't interact the same manner that electrons will because bosons don't obey the pauli-exclusion principle, so as many of them can go in one point as possible.
Dec8-05, 08:29 PM   #17
Recognitions:
Quote by leka
3. Explosion!!
Thanks again
I thought I'd already mostly answered this?
1) No. (but see 2b).
2a) Yes - there is a small photon-photon cross section in QED. The photons do not "change" propeties, we simply observe the effects of the photon-photon interactions. An example of this sort of photon-photon interaction is the creation of e+ e- (electron/positron) pairs out of the vacuum. This is what the point of talking about the "Schwinger critical field" was. I'm sorry that I don't have a better reference for you, if you google for more information on this you will do yourself a service in answering your own question. If you put enough photons in a box, you'll exceed the Schwinger critical field, and you'll start to see electron-positron pair production in the box.
[note: I know enough about QED to know that this happens, but not enough to do detailed calculations. You might do some reading and ask for more information in the quantum mechanics forum if you are still interested.]
As Zapper-Z notes, this is totally impractical to do _in a box_. It's not so impractical to do this _without_ the box, simply by creating a high enough intensity laser beam, though it's still quite ambitious.
Look at the following abstract, for instance
http://www.ncbi.nlm.nih.gov/entrez/q...&dopt=Abstract
Kansai Research Establishment, JAERI, Kizu, Kyoto 619-0215, Japan.
A method to generate ultrahigh intense electromagnetic fields is suggested, based on the laser pulse compression, carrier frequency upshift, and focusing by a counterpropagating breaking plasma wave, relativistic flying parabolic mirror. This method allows us to achieve the quantum electrodynamics critical field (Schwinger limit) with present-day laser systems.
2b) Even more exotically, eventually your box will be massive enough to form a black hole. (See the related thread in the GR forum). Of course you can still add photons to the resulting black hole.
3) Yes - but this is due to mundane failure of the box, not to anything exotic. As you add photons, the pressure increases. Eventually, any box will explode with a high enough pressure. (But this is a realistic concern, which you were not concerned with?)
4) Unknown phenomenon are unknown, how can we talk about them?
5) I'd rather not speculate - that's not what PF is here for, it's to explain known science, not to speculate.
Thread Closed
Thread Tools
Similar Threads for: Thought Experiment
Thread Forum Replies
thought experiment Special & General Relativity 34
A thought experiment Special & General Relativity 117
Thought Experiment General Astronomy 10
A Thought Experiment General Physics 125
