Solving Vector Problem B: Find Magnitude & Direction
  • Thread starter Thread starter cowgiljl
    Vector
The discussion revolves around a vector problem involving a ship's velocity across a lake while encountering a current. The subject area includes vector addition and the calculation of resultant velocity, specifically focusing on both magnitude and direction.
  • Participants discuss calculating the resultant velocity using both graphical and algebraic methods. Some emphasize the importance of distinguishing between speed and velocity, while others suggest writing vector equations to clarify the problem.
The discussion is active, with participants providing different perspectives on how to approach the problem. Some guidance has been offered regarding the need to calculate both magnitude and direction, and there is an exploration of vector components. However, there is no explicit consensus on a final method or solution.
Participants note that the problem specifies the need to calculate resultant velocity, which is a vector quantity, and there is an emphasis on ensuring that both magnitude and direction are addressed in the calculations.
cowgiljl
A ship sails due east across lake at 19 mi/hr. The ship encounters a current flowing due northat 3.00 mi/hr
A calculate the resultant velocity ( be sure to calculate the magnitude and direction)
I drew a picture
R^2 = 19^2 + 3^2
R = about 19 mi/hr
B) In what direction should the ship head in order to offswet the effect of the current
tan-1 (3/19) = 8.97 degrees n of east
Just need some reassurance I am doing these right
First of all write vector eqn in terms of i,j,k components
then apply
[tex]V_a_b = V_a - V_b[/tex]
rel velocity of a wrt b= vel of a - vel of b
Always try to write vector eqn if you are not able understand graphically and derive the results accordingly
Two points:
1) The problem said "calculate the resultant velocity " NOT "speed".
Technically, velocity is a vector quantity.
2) The problem specifically said " be sure to calculate the magnitude and direction"
You have only given the resultant speed (magnitude of the velocity).
You should either find the angle (arctan(3/19) north of east) or
(much simpler) write the two given velocities as vectors and add:
Using the standard convention that <1, 0> is east, <0, 1> north,
19 m/h n is <0, 19> and 3 m/h e is <3, 0>
The resultant velocity is <3, 19>. That was easy!
  • · Replies 16 ·
