Calculating the Total Length of a Spring with Varying Masses
  • Thread starter Thread starter Punchlinegirl
    Mass Spring
The discussion revolves around calculating the total length of a spring when different masses are suspended from it, specifically focusing on the application of Hooke's Law and the effects of varying weights on spring extension.
  • Participants explore the relationship between mass, spring constant, and extension using Hooke's Law. Questions arise about the correct method to find the unstretched length of the spring and how to apply the calculations for different masses.
Participants are actively engaging with the problem, sharing their calculations and seeking clarification on their reasoning. Some guidance has been offered regarding the arithmetic involved in the calculations, and there is a recognition of the need to verify results.
There is an emphasis on understanding the unstretched length of the spring and how it relates to the total length when different weights are applied. The discussion reflects a learning environment where assumptions and methods are being questioned and clarified.
Punchlinegirl
A 6.00 kg mass suspended from a spring with spring constant, k = 975.0 N/m, extends it to a total length of 0.250 m. Find the total length of the spring when a 15.20 kg mass is suspended from it.
I drew the free body diagram to get,
ma= kx- mg.. since a= 0, kx=mg
solving for x gave me mg/k
So I did (6.00)(9.8)/ 975.0 = .0603 m
Then I did (15.2)(9.8)/ 975.0 = .153 m
I didn't really know where to go from here.. do I subtract the values? Or am I even going about this in the right way?
Thanks
Hint: Find the unstretched length of the spring.
so to find the unstretched length I use Hooke's Law
F= -kd
So it would be like what I had before, mg/k= d
(6.00)(9.8)/ 975 = .0603
since the total length is .250, I do .250-.0603 to get .1990 m.
Is this right?
Right idea, but check the arithmetic.
Ok I figured it out. Thanks Doc Al!
  • · Replies 56 ·
