Optimization With Inequality Constraints:
lynxman72
Hi all, I'm having trouble with the following problem: It was given as a word problem from which to infer the mathematics but basically it is this:
Maximize: f(x,y,z,t,w)=
ln((y^2-x^2)(z^2-t^2)*w^3)+.8x-1.2y-20z/17+14t/17-w^3/(pi^3)
Subject to the constraints:
0<= .5x+y+3z+3y+2.5w<+30
1800<=+130x+150y+200z+70t+110w<=3000
the problem is I don't know how to handle constraints like these, where there is an upper and lower bound, and I'm just confused because it seems like there is a lot going on...the only thing i knew how to do to
1) remark that the max exists because the function is defined on this closed and bounded set 2) compute all of the partials set them equal to zero and find the critical points and hope that I would find the global max and the values at the global max would lie inside the constraints, but this didn't work because when I do this I get the critical point
(2,3,7/3,10/3,pi) which doesn't satisfy the second constraint.
I know that when you have a function defined on a closed bounded set to find the local max you find the crit. points and test the values at the boundaries and just compare but i don't know how to obtain bounds on each individual variable from the constraints or what to do. any help would be appreciated
oh sorry by the way I also know that each variable is >=0 from the context of the problem (each variable represents a serving of food). thank you
If you take the first order partials, set them = 0 , and solve the resulting system, you get:
x = 2, y = 3, z = \frac{10}{3}, t = \frac{7}{3}, w = \pi
but these values do not fit the first constraint, namely that
0\leq \frac{x}{2}+y+3z+3y+\frac{5}{2}w&lt; 30
in fact those values of x,y,z,t, and w, will give \frac{x}{2}+y+3z+3y+\frac{5}{2}w=23+\frac{5}{2}\pi = 30.86 \mbox{ (appox.)}
Also note that f(1,1,6.70000000000000016,1,1)=-\infty.
Right, I was just saying all I could figure out how to do was try to find this global max and hope it fit the constraints (it didn't), so any advice on another way to proceed?
Crap, I minimized. Let me look again.
Well, you might try Lagrange Multipliers with the constraints as equalities for the upper and lower bounds of the inequalities.
That version of Lagrange Multipliers goes:
To find the extrema of f(x,y,z,...) subject to the constraints g_{1}(x,y,z,...)=k_{1}, g_{2}(x,y,z,...)=k_{2}, g_{3}(x,y,z,...)=k_{3},... set
\vec{\nabla} f(x,y,z,...) = \lambda_{1}\vec{\nabla} g_{1}(x,y,z,...) + \lambda_{2}\vec{\nabla} g_{2}(x,y,z,...) + \lambda_{3}\vec{\nabla} g_{3}(x,y,z,...) +\cdot\cdot\cdot
and solve as normal.
So what you're saying is then I will have four Lagrange multipliers? I treat it as four constraint equalitites?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
