Energy Quantisation: Understanding the Reason
The discussion revolves around the concept of energy quantization in quantum mechanics, specifically in relation to the time-independent Schrödinger equation and its implications on wavefunctions in various potential energy scenarios.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between energy values and the behavior of wavefunctions in classically allowed and forbidden regions. Questions arise regarding the conditions necessary for smooth connections between solutions and the implications of normalization on energy quantization.
The conversation is ongoing, with participants attempting to clarify the mathematical relationships and boundary conditions that lead to quantized energy levels. Some guidance has been offered regarding the counting of solutions and matching conditions, but no consensus has been reached on a precise method for demonstrating these concepts.
Participants are navigating the complexities of wavefunction behavior in different potential energy scenarios, with an emphasis on normalization and matching conditions that influence the existence of discrete energy levels. The discussion reflects the challenges of reconciling theoretical concepts with mathematical formulations.
ak416
Ok, I am reading this part in my book that tries to explain the reason for energy quantisation. It first shows that the time independent S-eq is a an eigenvalue equation, and writes it as: d^2/dx^2 Y(x) = 2m/h^2 [V(x) - E(x)] Y(x) where i use Y instead of "Psi". It gives a graph of an arbitrary potential approaching V- as x-> -inf, V+ as x-> +inf and has a min of Vmin. It considers 4 cases: E < Vmin, Vmin< E< V-, V-< E < V+, E > V+. I understand the first case is physically unacceptable because Y(x) has to be concave up if at some x=x* Y(x*)>0, concave down if Y(x*)<0, and "escapes" from the x-axis if Y(x*)=0 and due to the probabilistic nature of the wavefunction, Y(x) must be finite. Now for the second case, Vmin < E < V-, there are two points of intersection between E and V, call them x1 for the left intersection and x2 for the right. I understand the Y(x) must oscillate when x is between x1 and x2. Also if x<x1, then it can converge either to the left or to the right and if x>x2 then also it can converge either to the left or to the right. Now since we're assuming V is finite and continuous everywhere it follows that d^2Y(x)/dx^2 and dY(x) are also continuous. The book tries to explain that because the d^2Y(x)/dx^2 depends on E, then the curvature of Y(x) depends on E, then there may be certain discrete values of E for which the solution in the internal region will join smoothly with to the solutions in the external regions, and they say that such solutions which are finite, continuous and having a continuous derivative everywhere are eigenfunctions of the time independent S-eq.
I don't really understand what they mean...why can't you have any value of E creating this smooth connection between the curves?
The idea is that the exponential decay outside the classically allowed region is controlled by a different parameter than the parameter that controls the oscillations inside the classically allowed region. Both these parameters depend on E, but the matching conditions at the boundaries are going to involve these two different parameters. In other words, you will obtain a self consistent equation for E. Now, the equation is rarely algebraic, but you can still convince yourself that it isn't going to allow for a continuum of solutions. So in some sense, quantization is generated from the fact that you have to match two qualitatively different solutions with matching conditions that involve the energy. However, the hidden key is normalization. Without this condition you have enough freedom (from the extra solution) to choose your E in any way you like. This is why scattering states have a continuum of energies, when you change the energy you only change the relative weights of the two linearly independent solutions (which are both oscillatory). In the language of scattering theory, all this is saying is that reflection and transmission coeffecients are energy dependent. Interestingly however, one can still see the vestiges of quantized energy in certain resonance phenomenon in scattering theory.
I kind of understand, but is there a more precise way to show this?
Sure, just count! Here is what I mean: with normalization, you have 1 solution in the right classically forbidden region, 2 solutions in the classically allowed region, and 1 solution in the left classically forbidden region. Including the energy that's five constants you have to nail down. Now, one of these will be determined by normalization, so you are really left with only four constants. How many matching conditions do you have? Well, you have exactly four since you require continuity of the wavefunction and its first derivative at two different points. Four equations and four unknowns, and while you will generally have multiple solutions (several bound states) its clear that you aren't going to get a continuum of solutions.
I encourage you to try a similar kind of counting for scattering states to convince yourself that the system has a solution for each E.
  • · Replies 20 ·
