Calculating Stretching of a Wire: 2.5m Long
  • Thread starter Thread starter naeblis
    Wire
The problem involves calculating the stretching of a wire that is 2.5 meters long, with a specific cross-sectional area and a mass applied to it. The context is related to material properties, specifically Young's modulus.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to apply the formula for Young's modulus to determine the stretch of the wire. Some participants confirm the setup and arithmetic, while others point out the need for unit conversions.
The discussion includes confirmations of the original poster's approach, with some guidance on unit conversions provided. There is an acknowledgment of a minor oversight regarding units, but no explicit consensus on the final answer.
Participants are discussing the implications of unit conversions in the context of the problem, highlighting the importance of dimensional analysis in calculations.
naeblis
hi i was wondering if i did this correctly.
Q: A wire 2.5m long has a cross-sectional area of 2.5 mm^2. It is hung vertically and a 4.5 kg mass is hungfrom it. Byhow much does the wire stretch if Young's modulus for that material is 2.0 x 10^11 N/m^2 ?
so i did Y = ( F / A ) / ( del L / L )
2.0 x 10 ^ 11 N/m^2 = (( 4.5 kg * 9.81 m / s^2 ) / (0.0025 m^2)) / ( del L / 2.5 )
delta L = ((4.5 kg)(9.81 m/s^2)(2.5m))/((.0025m^2)(2x10^11 N / m^2))
= 2.21 x 10 ^ -7 meters
You set it up correctly. Assuming your arithemetic is right you got it.
-Dale
1 mm = 10^(-3) m
1 mm² = 10^(-6) m²
2.5 mm² = 2.5*10^(-6) m²
Apart from that, your working is fine. Just multiply your answer by 1000.
Oops, I missed that. Quite correct Fermat.
-Dale
  • · Replies 19 ·
