Calculating Electric Field for Infinite Plane Slab with Uniform Charge Density
The problem involves calculating the electric field generated by an infinite plane slab with a uniform charge density, specifically determining how the electric field varies as a function of the distance from the center of the slab.
  • The original poster attempts to calculate the electric field and presents a formula, questioning its correctness. Other participants challenge the assumption that the electric field is constant within the slab and suggest using Gauss' Law to analyze the situation. There is discussion about the setup of a "pill box" to apply Gauss' Law effectively.
The discussion is ongoing, with participants exploring different interpretations of the problem and questioning the assumptions made regarding the electric field's behavior within the slab. Some guidance has been offered regarding the use of Gauss' Law and the setup of the pill box for analysis.
Participants are navigating the implications of symmetry and charge distribution in their calculations, and there is an emphasis on understanding how the electric field behaves at various points relative to the slab.
Midas_Touch
Problem: An infinite plane slab, of thickness 2d carries a uniform charge density rho. Find the electric field as a function of y, where y=0 at the center. Plot E versus y calling E positive when it point in the +y direction and negative when it points in the -y direction.
Okay, so I worked out the electric field, which gave me
E = 2d*rho/epsilon_0
Does this look right?
No. The field is not constant for -d < y < d.
I used the integral of E.da = Qenc/epsilon_0
E.4d^2 = rho*8d^3/epsilon
What am I doing wrong?
Set up a "pill box" (cylinder) whose center is at y = 0 and whose flat faces are parallel to the plane y = 0 and equidistant from it. By symmetry, the electric field is perpendicular to the flat surfaces (but perpendicular to the curved surface) so the only contribution to the flux is from the flat faces.
That flux is related to the total charge enclosed by the surface (Gauss' Law) and depends on the height of the pill box. Clearly, when the height of the box is 0 then the charge enclosed is also zero so the flux and electric field at y = 0 is 0. If you make the box taller, then the amount of charge it contains increases. You need to figure out how much charge is contained and it will be proportional to 2xE(y) x Area of flat surfaces.
