Electric Filaments: Safe in Water?
  • Thread starter Thread starter mtanti
    Submerged
The discussion revolves around the safety of electric filaments in water, particularly in the context of electric kettles and water heaters. Participants explore the mechanisms that prevent short circuits when heating elements are submerged in water, comparing these devices to other electrical appliances that may pose risks when in contact with water.
  • One participant questions how electric filaments in kettles remain safe in water, contrasting this with the dangers of other devices like hair dryers.
  • Another participant explains that the filament is insulated and contained within a tube, preventing direct contact with water.
  • Concerns are raised about the potential failure of the insulating tube, which could lead to safety hazards, but it is noted that this should ideally trigger a circuit breaker.
  • Some high-powered devices use deionized water to ensure high resistance, which is a safety measure in their design.
  • A participant seeks further information about the insulating substance used in immersion heating elements.
  • It is mentioned that immersion heating elements typically consist of a heater wire surrounded by a ceramic insulating material within a metal tube.
Participants express a range of views on the safety mechanisms of electric filaments in water, with some agreeing on the importance of insulation while others highlight potential risks. The discussion remains unresolved regarding the specifics of insulation materials and their effectiveness.
There are limitations in the discussion regarding the specifics of the insulating materials and the conditions under which they may fail. The conversation does not resolve the potential risks associated with different types of heating elements.
mtanti
I'm not sure if this is the place to post this thread but how is it that an electric filament in an electric kettle or water heater doesn't short in the water? What makes it safer then a hair blower falling in a bath tub?
Because it is like why you don't drown when you go scuba diving. The important stuff is not in contact with the water. The filament itself is inside a tube that is inside the water. A substance that is an electrical insulator is between the actual filament and what is called the element.
Sometimes a heating elements insulating "tube" will fail. Hopefully current will flow to the tanks ground causing a circuit breaker to trip.
Some high powered devices are directly cooled by water flow but the water is deionized and carefully monitored to ensure a very high resistance.
And what might this substance be? Any extra info I can find?
Immersion heating elements are usually consist of a heater wire ( e.g. nichrome) surrounded by a ceramic insulating material all packed inside a metal tube make of maybe aluminum or Stainless steel.
  • · Replies 22 ·
16K
